srm
I laid and maintained my own moorings for a number of years. The advice above is good, but be aware that even in areas with no significant current the bottom of the riser, where it lifts on and off the sea bed with the rise and fall of the tide can be subject to the most wear, especially on a sandy bottom. I have seen chains that look good, until you push the links apart and see the wear/sand abrasion on the faces between the links.Have a good look at the state of your mooring. Chains wear surprisingly quickly, so look for wear where the links touch each other. Any significant reduction in thickness and the I wouldn't be happy leaving the boat. Lift the buoy and check as many links as you can see, plus the swivel.
