Hamma
My SO32 (2003) has a Cristec charger I guess you probably have the same. I've had no interference problem but mine is under the rear cabin berth so the extra distance might squash it.
If you have a power outage of even a fraction of a second the charger will reset and go into 5 hours boost mode so if leaving for a long period, boost should be disabled with an internal switch. Manual at http://www.cristec.fr/en/out-of-date-products/cps-chargers.html
I had a poke around under the chart table today and discovered that it is indeed a Cristec charger - so thanks!
I had downloaded the manual and noted the warning about leaving the charger on on all the time with Boost enabled - so I opened it up and disabled the boost function.
When I got home and saw the photos on the Cristec website I realised I have a second generation Cristec - the CPS2. The manual for the actual model I have (12v/25A) claims that it will not utilise boost if the batteries are fully charged. There is no warning regarding setting boost off when the mains is permanently connected.
If anyone can be bothered this is the link to the manual.
Since there is no warning and the manual states that the unit will not attempt to Boost-charge full batteries... does the panel think I will be fine reseting the switch to boost?
I realise this is very esoteric and not a little boring so I do appreciate speculation and opinion. Just looking for a little input as this stuff was last covered by me in the 1980s when batteries were called Ever Ready.
