alan43
My boat has a VDO-Sumlog speed/log instrument with a hull-mounted propellor-type transducer, ie., NOT a paddlewheel.
Unlike the device described in a previous discussion thread, this propellor is not mechanically linked by cable all the way to the display unit, but has an interface just inside the hull, from which there is a 2-wire connection to the display unit.
This arrangement still works after a fashion, the speedo reading is at least plausible. However the log function does not work, and I would really like to replace the instrument with a more modern display. (The boat was built in 1978, & I think the instrument is original.)
Since the impeller still appears to be functional, I would like to continue to use it, rather than drill another hole in the hull to mount a paddlewheel. I have no reluctance to make up any necessary electronics, but I need some information first.
1 - Does anyone know about the sender unit for the Sumlog? Is it something as simple as a voltage-free contact closure (reed relay) for each 'pulse', or a solid-state switch, or is there any voltage or current actively generated by the device? Do I need to be concerned about supply or signal polarity? (So far no luck in getting this information from VDO.)
2 - Since I want to connect to an instrument which would normally have a paddlewheel input, then I need the same information about paddlewheel sensors. (Are all paddlewheels the same in these respects?)
3 - It would be nice to know the speed/frequency ratios for both the Sumlog and a typical paddlewheel.
Any assistance warmly appreciated.
