Suez blocked.
mjcoon
18 Jun 2011
Berkshire, UK
www.mjcoon.plus.com
Someone mentioned helium earlier? Guy Martin did something on tv and it was something like £36,000 worth of helium just to lift a person.
It's not inexhaustible and better kept for MRI machines!
(Though come to think about it, if we ever get nuclear fusion going rather than being forever 50 years in the future, we could start making helium from plentiful hydrogen...)
Adios
20 Sep 2020
Two reasons:
I think that with such a big ship with such a lot of ground reaction the risk of damaging the structure by applying too much force is very great. Better to get her almost floating and pull gently.
Also it takes a lot of setting up, with ground anchors barges wire blocks and so on.
I guess if it got tipped over and blocked the canal on its side it might be an issue for more than a few weeks? :LOL:
JumbleDuck
8 Aug 2013
SW Scotland
Is there some true in the idea we'll run out of helium and thats it gone forever for some reason? And we need it for some medical devices so party balloons are irresponsible? Might be a deal breaker
Yes indeed. Liquid helium is used to cool the superconductors used in MRI machines (amongst other uses) and the only source is from natural gas, mainly in the US. It cannot be distilled from air because, like hydrogen, the molecules are so light that they rise up and diffuse away through space. Any waste of helium is criminal irresponsible.
(Spent a few years of my life testing things in liquid helium, If my gas returned was short by a litre or more, I was expected to explain why.)
JumbleDuck
8 Aug 2013
SW Scotland
About nine hundred tons of pull in that picture costing sums of money that even oil companies had to think about.
During childhood holidays on Bute I watched the rigs built at McAlpine's yard at Ardyne grow over the year and then disappear down the Clyde. The biggest one (Cormorant Alpha) was a monster.
ITH
28 Jan 2005
Winter in Kent, rest of the year on board
rea
As tunnelling shields are to the London Underground, so cutter suction dredgers with their attendant craft, such as hopper barges, are to the Suez Canal. They had the “10th of Ramadan” working on the stern, earlier, but that’s free now. yes
Perhaps Kukri could advise whether the cross-section area of the canal would allow engineering works (some form of temporary flood barriers) to be erected N and S of the vessel to increase the water level - thus providing sufficient extra lift to refloat her?
Kukri
23 Jul 2008
East coast UK. Mostly. Sometimes the Philippines
rea
Yes, that would work, but the banks of the Canal are quite near the normal water level so you would need to raise them also. It is a practical method but it would be slow and expensive.
  • Like
Reactions: ITH
westhinder
15 Feb 2003
Belgium
Warning: can bore for Britain about this.
You can use what is known in the salvage business as “beach tackle” to use a lot of power to refloat a grounded or indeed a beached ship. It works really well, if you have time.
I’ve seen it done using very large wire rope blocks; the real specialists at that used to be Malayan Towage and Salvage, who are Filipino not Malaysian, and they used to use big flat topped barges with blocks carefully welded to the deck and huge anchors laid out to seaward. Each barge had a couple of fixed blocks and the moving blocks were (carefully) welded to the strongest bits of the ship, Backed up round other strong bits, as you don’t want bollards flying off in your direction, and the ship was sometimes well up in the mangroves where a typhoon had dropped her.
A tug then took the “hauling part” of the wire rope and steamed off with it, sheering vigorously, and the “immovable object” thought better of it as several hundred tons were applied! If necessary the barges could be repositioned and the process repeated. In Malayan’s cases, it was sometimes necessary to fight off guerrillas at the same time. They tended to get good salvage awards.
The legendary Captain Kato of Nippon Salvage got this British passenger cargo ship, seen here in her “post typhoon” state, afloat, and undamaged, with a combination of beach tackle and digging her own private canal. She had been on her side; he’d already got her upright by this point:
The method you describe reminds me of the barges with giant blocks and tackles used to right the Herald of Free Enterprise before she was floated off
sarabande
6 May 2005
Thames barges used to take the ground as part of their coastal trade, and it was not unknown for the flat-bottomed hull to stick to the mud and the barge to be swamped by the rising tide. The standard method of unsticking was to bang a heavy weight on the frames to liquify the mud on the outside of the hull and reduce its 'suction' power. That would be an interesting idea to run one of those giant Bomag vibrating rollers on the Ever Given's deck.
mjcoon
18 Jun 2011
Berkshire, UK
www.mjcoon.plus.com
Yes, ditto, but research rather than testing. We pumped on the liquid helium to get lower temperatures and then captured the gas in radiosonde balloons that started on top of our cupboards and spread across the ceiling. Eventually there was a liquid nitrogen machine installed in the college basement but helium was still bought by the Dewar.
Adios
20 Sep 2020
Here is an idea of how to refloat it and unblock the Suez canal,it can be expensive, but it can work
I wonder if they have started working on various alternative methods now or if they are going to wait for each method to fail before spending the money on the next idea. I'm guessing the latter so any Chinese made things I think i'll be wanting this summer I'm ordering now.
