Refueler
OK ... update ....
Last small bits of furniture removed and extent of crack found. Outboard keel to hull joint is fine internally. But inboard keel to hull joint is cracked entire length of keel to hull joint ...
Plan to grind out .... fill with resin / matt rode ..... then glass in L shaped strengthening ... that is hull then over the repaired crack and down into keel space. Partition bulkheads will be renewed where possible once glass work done. Extra glass work then to consolidate partition ply bulkheads which also provide cupboard spaces etc.
