rotrax
I posted on here some time ago asking if any one else had suffered this problem. No reply, I did find one US Sailor who had the same issue with a different furler.
The Harken Cruiser furler on our boat had the jib removed, without issue, every winter. Unable to remove it during Covid it stayed up for over two years. Upon attempting to take it down last October, no go. The rigger went up the stick to release the shackle, down came the jib leaving the top swivel jammed tight at the top of the foils. He attatched a line to the lower shackle, I put a block below and I managed to winch it down. It was bloody tight all the way. Yesterday I disconnected the lower forestay fitting from the deck and removed the furling drum. This allowed me to take the short section of foil off, with the jammed top swivel on it. I removed it by tapping gently with a softwood block.
Upon inspection the internal bore is lined with three nylon bushes, now badly distorted and with signs of dragging. I am led to believe that the furler is obsolete and parts are no longer available.
If this IS the case, I shal find a fix. Watch this space...............................................
