richardbayle
New engine, went to Speed Seal for impeller and they're no longer in business.
Do any of you know if someone else has taken over?
Is it DZR brass? If not, I'd keep a close eye on it. If you don't know it's turned to copper, as brass is wont to do around sea water, it could get expensive.He machined a groove in some brass plate
I no longer have that boat but there was no evidence of dezincification when I last checked it. I doubt if the original cover plate was DZR.Is it DZR brass? If not, I'd keep a close eye on it. If you don't know it's turned to copper, as brass is wont to do around sea water, it could get expensive.
As I was desperate for spares for my speedseal life, my engineer pal ran up a batch of PTFE disks and metal ones from a supplier who described the material as "bronze specified for naval applications". It is not the same material as the originals. I am a rotarian and my plan is to sell the excess (quite a few due to minimum materials order), defray materials cost and then give any surplus to charity. These are to fit the pump on a D2-40 and come absolutely with no guarantee of any sort at £10 for one of each plus post at cost. If this is of any value please let me know.
My one wore & prevented the pump working properly. I made one in brass 5 years ago & have not found any problem whatsoever. I feel that people can over think these things sometimes. I expect that wear on the face will happen long before dezincification.Is it DZR brass? If not, I'd keep a close eye on it. If you don't know it's turned to copper, as brass is wont to do around sea water, it could get expensive.
Rather soft copper with little mechanical strength will b e left which will wear away more quickly than the original brass would. You might not notice the dezincification as suchMy one wore & prevented the pump working properly. I made one in brass 5 years ago & have not found any problem whatsoever. I feel that people can over think these things sometimes. I expect that wear on the face will happen long before dezincification.
just out of interest - if dezincification did happen- what would actually happen then?
. It is not going to be true "copper" so will be rigid . So 8 years with a bit of luck & you may have to make another. Not exactly a big deal is it. The first one only lasted 10 years as well I think Volspec wanted £ 14-00 when i asked. Enough brass for 2 cost £4-50 Cut a disc with a hole saw, left it circular & drilled the holes for the screws in it. never bother with the paper gasket, always drips; use gasket compound. It is reversible so if it does wear I can just turn it over. (cannot do that with a volvo one as it has part Nos engraved in it which will damage the impeller) Job done.Rather soft copper with little mechanical strength will b e left which will wear away more quickly than the original brass would. You might not notice the dezincification as such
Yes indeed although they are on the boat. They are approx (using my very poor calipers) 40.44 diameter, 14.35 from edge of centre hole to outside, 11.5 hole diameter, 2mm thick. If interested perhaps move to PMHave you still got any ptfe discs for the speed seal life ?
ainsley
