andsarkit
I would usually prefer to run separate cables for each device but a soldered joint can work well. If you use adhesive heatshrink and pinch the tubing between thje two wires while the glue is soft it will seal around all the wires. When the glue is cool it becomes rigid and there is no strain on the solder joint and no flexing either..Generally that is something I avoid, but every time I have used a good heat shrink with a generous amount of adhesive, it easily sealed around both wires, and between them as well. Is this a non-problem?
Ordinary heatshrink in this application is a complete waste of time as it does not provide waterproofing or adequate support.
Also going against convention my boat was originally wired with household twin single core cable. This has the advantage of the insulation sealing around the copper so water cannot wick down the cable. Also any slight corrosion can be removed from the terminations which is difficult with multistrand cable. In over 50 years none of the cables have failed through vibration. Whilst I would not recommend this to anyone and I have always tried to use tinned multistrand cable for replacements and additions I try not to be too pedantic about these things.
