deep denial
Hi. Having difficulty with solar panel. Removed the old one which wasn't charging, and replaced with a new 100W panel, running through a Steca Solsum 10.10F charge controller to a 240Ah 12v battery bank. Voltage out of the panel is good, but can't get any rise in voltage of the battery bank. Shows 12.45 volts whether panel connected or not (All polarities connected correctly!) As part of my investigations I have found that there is discontinuity between the two negative terminals on the charge controller, ie the one from the solar panel and the one from the battery. Surely the negative terminals should be electrically connected? Or is that not the case?
