B27
You have to be aware of what the bulb is telling you.Can one use an LED ' bulb' for this task ? IIRC they can light up at lower V than normal incandescents.
Viewing a 2W LED bulb in daylight, I find it easy to tell whether it's managing to draw a watt or more from some wires.
It's telling me there is power there, it's not telling me it's 10, 12 or 14V
Very handy for checking connectivity, polarity etc.
If I wanted to check for voltage drop I'd maybe load up the circuit and measure the voltage drop.
There are LED bulbs with simple resistors to limit the current, thee vary in brightness in a simple relationship to the voltage. They generally don't light up if the polarity is wrong.
There are other LED bulbs which regulate the brightness and look the same from maybe 10 to 30V. Some of those have rectifiers built in and will not care about polarity and may or may not care whether it's AC or DC.
Bulbs and meters are 'indicators', it helps to understand what exactly they are indicating.
