Melody
For your Coastal Skipper course plan to spend as little time as possible down below. You won't be expected to be at the chart table for hours. Wrte a good passage plan on a sheet of paper or notebook you can stick in your pocket.
You'll need to put fixes on regularly. Practice 3 point fixes so you can do them quickly and use range and bearing where possible as it'll be quicker. You'll have to demonstrate you can navigate without relying on electronics but, once you've done that, you should be able to use modern equipment to help you.
Plan before you go to sea as much as possible. Think of alternatives, bail-out options etc before you leave.
Make drawings for pilotage with depths, distances, bearings etc and have it in your pocket. You should be on deck when within sight of land anyway.
Don't make the mistake of thinking you have to spend a lot of time below on your course. You don't. You'll be fine. As others have said, the situation you describe is one where many people would feel queasy, and not a reflection of how you'll be out at sea.
