Ian_Edwards
The manifold which houses the stand pipes for the diesel engine and the heater, along with the return lines and fuel filler line on my Vetus Polypropylene diesel fuel tank is leaking.
It has been refitted with some sort of "black sealant" but when the tank is full, or when the boat heels, diesel seeps out of the joint between the tank and the manifold.
What's the best way to seal the joint?
Is it better to use a mastic type sealant, an "o" ring or something like a thin sheet of Nitrile Rubber?
Is there an internal ring which will fall out when I loosen the screws which hold it inplace?
