Bouba
Yes, it works now......deleted - as I noticed I'm a bit behind on events..
Correct, it will only shut - clockwise - whichever way you mount the handle.if the seacock is open then it will only go one way
I haven’t yet watched the video....but the engine inlet has a strainer over it...so a seabung won’t workHave you not heard of seabung?
Just replace it in the water. Its seawater not diesel.
https://www.svb24.com/en/seabung-emergency-plug.html
Paul, there is no concept of "correctly fitted". In that picture, when closed the handle would be sticking out sideways to the right, because it can only go clockwise when the handle is mounted like that. So the handle has 2 positions = pointing up and pointing to the right
The handle can be repositioned 180degs from what is shown in that picture (no other choice is possible, only 180 degrees). If you do that, which means removing the handle and refitting it upside down, it would be pointing vertically down in 1st picture of post 26. Then, the handle has 2 positions, being pointing down and pointing to the left.
That's my point = these things are reversible to allow you to arrange valve handles in any way you want after you have installed the valves, which is especially useful in a busy installation. There is no concept of "correctly fitted"
The only logical reason why you think you couldn't close the valve because of the stopper is that, looking at your 2nd pic of post #24, you tried to rotate the handle CCW.The handle was against the stopper with the valve open..when I removed the handle and replaced it at 180 degrees...the handle was able to turn and close the valve.
Latest news
Tomorrow the port will tow the boat to takeout and leave it in the slings overnight…so that I will have all the time in the world to do the job…and probably enough daylight hours to go to the chandler for emergency supplies. The port also gave me the number of a repairman just in case
Bouba, if that's what you experienced, I take your word for it.when the handle was one way it could not move…when I put it at 180 degrees it can now open and close
Just ring the repairman. Sounds like the Port might have prewarned him !Latest news
But I have to report the truth… if someone buys a new seacock from the chandler and no matter how hard they try it will not move…then remove the handle and replace it at 180 degrees.Bouba, if that's what you experienced, I take your word for it.
But by saying that, you suggest something that (also for future reference to anyone reading this thread) doesn't make any sense, i.e. remove the handle and rotate it 180°, which doesn't change one iota.
See my previous post for the only 2 possible reasons behind your experience.
Yes, they phoned to see if he is available just in caseJust ring the repairman. Sounds like the Port might have prewarned him !
Drowning my sorrows is strangely inappropriateEmergency supplies ? Close to the pub is it ??
With all due respect, given that you can't work out how to turn the handle (and still cannot grasp how it works) i would suggest getting the repairman in. Otherwise you run the risk of breaking something else, sinking the boat or not getting it sorted in time and having to pay the yard more money for chocking up and relaunching at a later date.Latest news
I find it difficult to believe you cannot grasp how the handle worksBut I have to report the truth… if someone buys a new seacock from the chandler and no matter how hard they try it will not move…then remove the handle and replace it at 180 degrees.
That I think is a far more important practical advice than the (untested) theory that the handle is reversible.
It might just be this brand
