Rusty keel bolts on otherwise very tidy boat - should I walk away?
running a die over the exposed thread is a waste of time. It’s only cleaning the exposed un-used part of the thread.
As you can see from my pics above the thread inside the keel is usually perfect so it lets go first.
I’ve changed keel bolts on several moodys, bilge and fin keeled. I’ve never had an issue with re-sealing in situ
Depends how you define "waste of time". Given how much upset the visible rust has caused the OP, it might be worth doing something about it, if only from an aesthetic POV, especially if one might want to sell.
Re the lack of problems re-sealing, that seems to imply that, if air can evidently get out, water might be able to get in.
The adv ice has been consistent - the "upset" is not a big issue. Cleaning the rust off and painting is straightforward and effective.
Air is very compressible a small pocket of air will push some sealant up the threads but that is all.
I think your missing the point, the op requires confidence, not a slap of paint to cover up, nobody can say the true condition internally, and all advice saying 'it'll be OK " isn't going to give him that confidence.
I am not missing the point. Confidence can come from asking the question as the OP has done and listening to the answers. Not one answer has indicated there is likely to be a problem. There is no suggestion that the keel has been damaged in any way or moved - so how can there be anything wrong with the studs? The tops which have been in water have some rust but still look the same size as original. No water can get past the nut sealed to hull. There are a number of examples on this thread of people who have removed nuts and studs in similar circumstances to find they are like new. Videos and photos as illustrations. Painting the tops after cleaning is an appropriate measure to prevent them rusting and looking unsightly in the future.
Seems like he has bought the boat anyway. Maybe he will remove one of the them and post a photo showing much the same as others have found.
A suitable conclusion?
After reading the posts.
Offer a lowprice, pay what the seller bids you up to (less than £5k hopefully) seal the keels from the the outside with a lot of adhesive ‘stuff’ (keels have been glued on - see PBO 1994 possibly) choose your stuff, ct1 pu40, Sikalfex this or that, treat bolts inside with rust converter, wax, epoxy, butyl… so many choices, use that bilge pump in photo on an automatic switch of your choice.
Insure, go sailing, enjoy.
Have safety devices (as all boats should have in case a keel falls off - VERY unlikely).
If only “ coastal cruising or estuary swim to shore” as I was once advised after paying lots of pound notes for pounds worth of gear safety gear I really didn’t need - oars, o/b, two anchors, flares, lifejacket… etc (especially as I was supposed to be an expert swimmer - but never assume either… dichotomy?)
What is £5k if you use the boat a fair bit?
And if keels are good, sell layer for same or similar or marked up price.
I always sold for a profit, but I always improved any boat I owned.
The engineer that the OP contacted suggested replacing the bolts, but I think that just pulling a single bolt to check its condition would be a better idea. I would also wait until the boat needs lifting for another reason, e.g. antifouling, as lifts are expensive.
At the moment he's anxious because the bolts haven't been checked. After checking he'll be anxious because the bolts have been disturbed.
Welcome to boat ownership!
It's his life and possible his family and/or friends, plus any emergency rescue people that my be put at risk, I agree he sould satisfy his concerns and be confident.
Im not suggesting for one moment that there is or isn't reason to be concerned, but setting out to sea with a doubt and a worry is not imho a good idea...
I'm sure you all are very capable of smiling if the captain of your next flight said there are some rusty old bolts, but i was assured by YBW that all is ok 👍
I think I qualify for that - I flew Sleazyjet the other day, and I only had to use my parachute once...
More seriously, I'd be quite happy to go with the advice to clean the rust off and undo a nut. If the bolt under the nut is sound, I'd be quite happy to clean up the others and go sailing.
5K? Id wager keel bolts could be the least of your issues with a boat that old. But if the rig, engine and overall feel has ticked the happy box then forget about the bolts. Just clean, seal and try to avoid hitting bottom too often. Start messing with them and a whole load of associated problems could develop. Keel bolts dont just pop out between lunch and afternoon tea. It can be a very expensive operation.
