Round Britain day 39
Concerto
16 Jul 2014
Chatham Maritime Marina
Last night I did not mention I may be moving again. The forecast was for SW 5 to 6 and I had not checked the tides, hence no comment. The alarm rang too early again, I had less than 3 hours sleep. Still a man has to do what man needs to do. I slipped out of the marina at 5.30, quickly hoisted the main with one reef, then continued to motor into wind. As soon as I turned northward (what, you are going the wrong way) and found I was travelling rather quickly. So, I only unrolled the genoa with a double reef. Not only was I travelling fast throught the water but the tide was in my favour giving a combined speed of 9½ knots, thank you very much. However I decided I should put the second reef in the mainsail. As I proceeded up Yell Sound, I headed for the western side for some protection from the wind and rain. Quickly I checked potential anchorages close by if I thought the wind too strong, plus a few places on the west coast of Shetland main island. Better to be prepared rather than hoping something will turn up. It was difficult to tell the exact wind direction because of funnelling due to the hills and valleys.
When I reached the Point of Fethaland, I cut between the point and some offshore rocks. As I hardened up I was able to make about 290 degrees. This was quite good as I needed a lot of westing to be able to tack on to the making leg down the coast. The sea was certainly rough and almost on the nose but I was making 5½ to 5¾ knots as close as I dare go. This tack was held for about 10 miles. Not knowing what the tacking angle would be in such rough conditions, I guessed when I thought I could make it down in one hitch. Starboard tack was much nicer as I was slicing over the waves and I could get 6+ knots. Using the autotack meant I initially tacked through 100 degrees, but had to harden up to about 90 degrees, however after tide and leeway played their part, the tacking angle was about 110 degrees. This tack I held for about 18 miles until I was close to Papa Stourand had to tack out again for a couple of miles. Once I passed this island I was able to hold this tack for a further 25 miles, gradually easing the sheets, until I dropped my sails.
It was a rough ride, but I can honestly say Concerto only slammed down twice after falling off the back of a couple of steep waves. I suffered a few problems that all need sorting urgently. The autopilot popped off the pin on the tiller arm, not once but twice. Watching it closely I realised the arm had become loose again, so the nuts need tightening. This is only temporary fix as I think I need to fit penny washers under the bolt heads to stop the wood getting compressed. Some of the waves broke on the deck and smashed against the sprayhood. This forced water through the slots in the breakwater used by the halyards. When sailing Concerto is slightly nose down, so the water does not run aft but under the companionway hatch. From here it somehow runs on to the backs of the headling panels inside the cabin and drips everywhere inside. One particularly massive wave forced water straight down the main hatch and soaked the chart table with my almanac, tide tables, pilot guide and note pad. This has never happened before, but I then closed the hatch in case it happened again. On board I have some sheet rubber and brass strips so will close the slots for the halyards almost completely and also fit some rubber to stop any water flow going into the hatch box. I should mention that most waves were 8 to 10 ft peak to trough, but some were 12 to 14 ft. Then some things moved in the forward hanging locker, forcing the door open. I could not get the stuff back in so it remained on the floor. As I turned to come back outside I saw a few drips coming from the starboard fore cabin window. The interscrews on the fore cabin windows have not been checked for tightness since I removed them to replace the headling, so they will both be checked tomorrow. The final item was the 3rd full batten on the mainsail decide to detach from its car, hopefully nothing is missing and can be screwed back together tomorrow. Currently I am warming the interior up to help dry out most of the moisture ingress.
So have you guessed where I ended up at? Scalloway. Berthed at the boat club, but that was very difficult berting. I was berthing cross wind on the lee side of the pontoon. The first attempt I had someone helping, but could not get the stern in, so slipped out to try again. This time I had 3 helpers and did get in but I certainly doubt I could have done it on my own. The wind is still blowing at about a force 6 with lots of heavy showers. Currently I have 9 lines out to secure Concerto.
Now for the facts on the journey. The measured distance is 63 miles, the vast majority to windward, so I probably travelled about 80 miles. This took about 13 hours, giving a speed over the ground of just over 6 knots. Considering I punched a lot of tide for hours on end, I feel that was quite reasonable. Luckily tonight I have mains electric as my domestic batteries were showing only 11.8V having started this morning at 12.8V with virtully no engine charging other than the solar panel over 3 days.
Late last night from the cockpit.
Passing through the narrows of Yell Sound. Look in the bottom left of the chart plotter to see the speed over the ground.
Cutting inside the rocks at Point of Fethaland.
The detached 3rd batten from the car.
Papa Stour.
This cliff has his hat on or does it just have its head in the clouds?
Approaching Scalloway.
Scalloway ahead.
For anyone wanting to read the reports from the start, this is the link to first one.
Round Britian day 1
srm
16 May 2004
Azores, Terceira.
Yes, it can get very lively off Esher Ness with the Atlantic swell mixing with reflections off the cliffs giving steep irregular waves.
We also had problems berthing on the boating club pontoon, but fortunately not as bad as you. When first in Scalloway we were living aboard on a mooring off the boating club's current location.
MADRIGAL
12 Jan 2019
What a rough passage for day 39. You and Concerto are made of stern stuff. Thanks again for telling the tale.
jamie N
20 Dec 2012
Fortrose
Scalloway Boat Club is full of 'characters'!
A couple of really good restaurants within a few hundred meters. One to the left at the college had some awesome scran, plus the pub Scalloway Hotel was good news.
The museum (as you'll know) is very good, and understated in some ways.
Concerto
16 Jul 2014
Today I decide to treat myself to a late cooked breakfast in Scalloway as I ate very little yesterday. Then off to the Scalloway Museum, which is very well worth visiting. The displays about the Shetland Bus are very detailed. On the way back to the boat I went into the Scalloway Meat Company, a butchers and general store for some supplies. It is much larger than you would expect and has everything from meat, vegatables, general foods, cleaning products, plus garden plants and tools, household tools, DIY and electrical items, toys, birthday cards, stationary, and is just about to open a crafts and art gallery.
One of the problems in the islands is finding a cash point as they are very limited due to the small population, Shetland has just over 22,000 people. In Lerwick and Kirkwall there are some banks, but elsewhere there are very few cash points in shops which charge a fee. When I checked online what cash points were available in Scalloway, nothing showed up. Chatting with a resident, I found there was a Post Office counter in the chemist where you can get cash out for free. There are 2 cash machines also, in Scalloway Meats and The Checkout (another food shop), which both charge a fee but do open later than the Post Office.
Back on the boat I have fixed the detatched 3rd batten. All that was needed was to remove the insert in the mast track, drop out all the sliders down to the 3rd batten and then rescrew the car into the batten and put all the sliders back in and replace the insert. How it came undone is a bit of a mystery. Took about 20 minutes. The forward window that had a slight weep has hopefully been fixed. One of the interscrews required 2 turns, so with all the interscrews tightened I doubt it will leak again. I also checked the other forward window with virtually no movement on any of the interscrews. I decide to leave the other jobs as it was getting quite cold. Checking the wind, I realised it had dropped sufficiently to fly the drone. After warming up , I then went and obtained some excellent video and photos with the drone. A message did pop up onscreen before I flew that there was an airport nearby and I must accept full responsibilty for my drone. Some of my photos from today have been reduced in image quality so I can post them below.
Looking at the wind and weather for tomorrow, it is looking much better to sail rather than on Wednesday when heavy rain is forecast. I am going to be close hauled in winds similar to yesterday, so I will try and go direct to Pierowall in Shetland. The distance is almost identical to yesterday, so very do able. This will save me a day by leaving out Fair Isle and the course is better and will allow less tacking than leaving from Fair Isle as this is to the east of the lay line. The slots in the spray rail for the halyards will be blocked with some cloth as a short term measure to stop any further water problems in the cabin.
Berthed alongside the high and sheltering pontoon of the Scalloway Boat Club. Astern in the blue hull is bristolfashion of this forum.
Looking down on the pontoon and clubhouse.
A pretty street in Scalloway.
Scalloway Castle, currently not open as under repair.
Scalloway Museum, just a small display. There were other sections I did not photograph.
The start of the Shetland Bus display.
More on the Shetland Bus and opposite.
The stained glass is of the first fishing boat built by David Howarth (author of Shetland Bus) in 1947 as he remained on Shetland after the war ended.
The Shetland ponies just added a local touch.
The outside display of some historic local boats.
jamie N
20 Dec 2012
Fortrose
I think you'll find that the 'Historic boats', are part of the fully competitive facing 'skiffy' fleet, with (perhaps) a sixereen in the background?
Others will know better than me I think.
As one who is acquainted with this sailing area, I'm unduly happy (and jealous) of you, and the manner in which you're experiencing it.
Concerto
16 Jul 2014
There should be nothing stopping you visiting then as compared to my home port you are a lot closer. :) :) :)
Juan Twothree
24 Aug 2010
I had to do a double take when I saw that picture of your chart plotter.
The latitude starts with a 6, not a 5. Crikey.
srm
16 May 2004
Azores, Terceira.
Have done it in either direction a number of times, no problem other than wind directions and tide overfalls off the north ends of both Westray and Papa Westray.
Once, heading north at the end of the summer with no wind I had to hand steer all the way as could not use the wind vane steering. A very cold clear night but entertained by a wonderful display of the northern lights.
