jac
My boat has a wholly inadequate domestic battery - single lead acid 105 Ah. As you might expect it’s on the list to address this winter. It’s not totally straightforward as the current space for batteries is full so some surgery/ re wiring will be needed.
However …My battery is dead. As in not enough to run a chartplotter and instruments for more than an hour or so despite a lot of charging.
So I’m faced with the choice of doing it properly, spending several weekends building new battery boxes, installing batteries, new cables, resetting chargers etc to a different profile or simply dropping in say one replacement AGM now and then over the winter, finishing the job.
I’m happy to buy a pair of larger AGMs now so they would be same chemistry, size, batch etc- it’s just that one would be used a few times before it’s partner got installed.
I know the “proper” answer is to spend the time now and do it properly bu if I do that I potentially write off most of what is left of the season (especially after deducting weekends when I’m busy anyway ) - so that leaves me with a simple drop in one now, accept the different battery profiles caused by use but enjoy a couple more weekends of sailing.
So my question.
Does anyone have any practical information on how much battery longevity will be affected if I just drop one in now and then do the other one in 3-4 months time?
I should say that use over the next couple of months will probably be day sailing, maybe a weekend or two but left over the week mid river with a small solar panel to ensure fully topped up.
So my question.
