PhilMay
I could not find a good description of this process, so I have written one to help anyone else who wants to fix their display.
See http://blog.mailasail.com/anastasia/489
This seems an unpleasant and critcal reply given the op posted something that over time may prove useful to many
Whilst the led underlying it maybe the same the product sold is 12v and 24v which the op pointed out needs to match the power supply of the unit.
If you have a solution to making the unit operate over a wide voltage range then why not post specifics ?
I agree, an ungracious / rude response. It takes time to write these things up and share them and that's to be encouraged.
You don't need 24 volt LED's as they are all the same LED and they only vary in the resistor which is fitted, perhaps looking at this and better understanding it a little more thoroughly would see you have several options which you could give to others, this can also be transferred to other forms of lighting and make an above average write up a superb write up.
I'm waiting for jfm to jump on this thread with instructions on how to make the leds colour-change
well done finding the PWM output on the circuit. Did you have a diagram or just poked about with a 'scope until you got lucky/intelligent guess?
Actually the point I chose is just the input to the high voltage transformers, so pretty much the first place I tried. I spent a long time trying to eliminate the glitch in the dimming, but it looked to me like the PWM is generated by the PIC microprocessor, based on a protocol exchange with the main processor. (That is just a guess based on what looks like a flurry of messages going into the PIC when you dial the dimmer knob.)
There is another PWM signal used to dim the keyboard LEDs, and that one does not glitch. I looked at using it to control the LEDs, but it does not have a common ground with the display power source so I would have had to introduce an optical isolator in order to decouple the signal. Also the keyboard LEDs turn off at full brightness, so it would have needed some more electronics to prevent that.
