Seasick Ian
The bottoms of my Hurley 22's encapsulated keels have a few large gouges and several smaller areas of damage. As far as I can tell the ballast is lead, and i've read that this is secured with steel bands. I can't see any evidence of penetration through to the ballast, which is a positive.
My plan for repairing is to
1. Strip away all paint around the bottoms to a height of about 5-10cm, using either paint stripper or just sanding.
2. Use a dremel to clean out the gouges and get all the damaged areas back to bare material.
3. Fill the gouges with thickened epoxy and fair.
4. Laminate over the whole keel foot and up the sides 5-10cm using epoxy and woven rovings, maybe adding some kevlar. This would be the reinforcement, I wouldn't mould a keel shoe or stick any metal strips to it.
Complications
There looks to be the remains of a GRP shoe that has been fitted previously. Should i glass around/over this or just remove completely? Might be a right pain to remove.
The boat is a bilge keel and obviously rests on the keels. I can do a certain amount of grinding and fairing around the sides/edge, but to access the actual bottom surface, I think I need the boat in the crane slings. The boatyard said I could do this, if I get the boat lifted first thing in the morning and then set to work, hoping the epoxy will cure before the boat goes into the water the next day. Is this feasible? Would there be any issues with the boat being in slings for 24 hours? The slings come together at one central point, so the straps will be 'pinching' the sides of the hull somewhat. Hurley's are supposed to be tanks, so maybe ok on that front. I've seen other posts where people have basically man-handled the boat, supporting one keel on chocks and the other side jacked up supports directly on the hull, freeing up one keel at a time. I've only seen this for smaller/lighter boats though, don't fancy my chances with the Hurley.
Thoughts?
Complications
Thoughts?
