kashurst
Is the diesel tank a fibreglass component built into the hull, or a separate metal tank?
Does sound a bit odd to have that much diesel swilling about.
Part of what I will be doing tomorrow, the engine has not been run since December, and I mopped up as much of the diesel as I could before I had to leave I'll see how much is under the tank tomorrow.The most likely place for a diesel leak is the engine....especially the return to the tank. But you have to check all connections and pipes from the filler cap onwards...if the tank is easily removed then you are very lucky, because even if it’s good it’s still worth inspecting, cleaning and even adding an inspection hatch. If it’s not easy to get out then your nightmare is just beginning
You might have dodged a bullet thereChecking under the tank I can find no leaks or drips, and the bilge there is still dry after a few days.
It is dirty water that is coming into the bilge in the bow and that is coming in slow, a few hundred ml over night, not even half a litre, where before it was diesel.
The concrete blocks in the picture above are releasing the stored diesel back into the bilge too, a lot of the planks are soaked in diesel and will be replaced, with others there is no way to replace them without splitting the boat and taking the cabin off, and that is just too much work for me, it will have to do for now, I have done it before but I was nearly 30 years younger then, and this boat would have been 12years old then
The tank is aluminium and feels solid, I have ordered up new flexible fuel hoses and a Racor filter/ water separator. They should be here on Monday and I can replace the feed and return to the engine. The filler hose is hard and I will have to cut it off to replace it
I have got some cleaner and waterproofing for it, just waiting for the weather to improve a bit to get it done, I got a waterproof canvas cover to put on the boat while the tent is off.
They look like a tribe of Vikings thinking about where to pillage nextToday is spring cleaning at the club …
Pressure washing the windows
Lunch now
Just home now and had a chance to look at the video, wow! it's even worse than mine!
Whatever language that is I reckon I could learn....it seems it’s 20% English....and another 20% that’s sounds EnglishJust home now and had a chance to look at the video, wow! it's even worse than mine!
At least mine can zip out and leave the frame on the boat
UltraMar is the stuff I got, it was not that cheap but is supposed to be quite good, I seen it on this channel:
It's Dutch, sounds like it's from Limburg or Brabant, not 100% sure. Certainly not ABN (Algemene Beschaft Nederlands = General Civilised Dutch) which is what they teach in school hereBouba said:Whatever language that is I reckon I could learn....it seems it’s 20% English....and another 20% that’s sounds English
Thanks, just the first treatment.looking good. what did you use to clean the covers? I have to do the same in a few weeks.
