blan321
My 1980s southerly has twin controls, one inside other on outside pedestal. Standard single lever Morse.
The gearbox linkage is fabricated slider. The throttle one
Is also a very simple slider for twin Bowden cable rods. You cannot undo control settings on the abandoned lever.
I would have thought duplicated throttle control on tiller quite easy along these lines, e.g. using seagull outboard throttle lever etc.
You would put single lever into idle in gear required, then use other lever for throttle.
Might that give you 80% of the control needed (or so!)
