dom
I have two, one on each cap shroud. When heeled, the windward one is near enough vertical.
(Note to self: replace cable-ties this year!)
Good idea, but unlikely to help much if you're talking about those dinky Plastimo tubes.
I think for sailing vessels ISO 8729-2 specifies a 7.5 m2 cross section for X-Band target performance up to 20 degrees heel. In practice, no non-active reflector can achieve this, so what one is looking for is a decent performance as measured by free-space radar cross section (RCS) across all azimuths from 0-360 degrees and all angles of heel up to 20 degrees. A few 'small' nul or minimal return points at specific heel and azimuth combinations don't matter too much in a bobbing boat. The key here is small.
Plastimo tubes are, alas, riddled with azimuth nuls at a zero angle of heel and almost useless from as little as 5 degrees of heel upwards. Consequently, adding a second won't do any harm, but will probably do little good either.
