Polycarbonate Hatch Repair
Aja
6 Nov 2001
Whilst looking around I came across this product with Force 4 Force 4 Polycarbonate Hatch Restoration Kit | Force 4 Chandlery
Anyone used it or something similar? My hatches are getting a big past it and I've seen the reglazing options but if this actually works then it might be a good alternative!
Quite likely your hatches are 'glazed' with acrylic.
Polycarbonate restoration kit may or may not work well with acrylic.
Aja
6 Nov 2001
It states that it will repair crazed surfaces; purely abrasive methods won't do that. Looking at the kit, I think they supply a liquid that will penetrate cracks, like Tolley's creeping crack repair.
As I alluded to above, this may work for polycarb, but no guarantee it would work for acrylic. A totally different material which is admittedly more prone to cracking, which in most cases (but not all) is non-strucrural. Polycarb tends to go opaque and can be polished to a certain extent.
Polycarb used in a marine environment has usually a protective film applied which assists with UV degradation see Lexan etc.. which lenses on a car won't have.
Using an abrasive on polycarb windows and hatches on a boat may not be a good idea.
AntarcticPilot
4 May 2007
Cambridge, UK
www.cooperandyau.co.uk
The small print on the website does say "It restores polycarbonate and plexyglass". I think plexiglass is acrylic?
davidmh
30 Jan 2015
Probably a rebadged kit that is used for refurbishing car headlamp covers. These are sometimes an abrasive paste with a polishing fluid. They do work but last about 6 months before the UV degradation starts again, dont know how it would deal wiith the scratches and crazing you often kept on hatches.
David MH
  • Like
Reactions: Aja
