shanemax
19.45 Friday. If anyone is interested there is a paddle steamer heading down the Orwell from Harwich.
That will be the PS Waverley19.45 Friday. If anyone is interested there is a paddle steamer heading down the Orwell from Harwich.
Correct. Your chance to go “doon the waater”That will be the PS Waverley
Good night picture.
Practically every pier she uses has been dinged by her at one time or another; she basically has no steerage until she's moving pretty fast, for the reasons given above.Be aware the Waverley is very tricky to steer, particularly berthing. No bow thrusters, the paddles no not operate independently, and she has very shallow draft with a very small rudder. So getting on and off piers needs speed and skilled handling of rope springs. Sometimes she has to leave going astern at high speed (look carefully at picture on timetable), and woe betide any small boat that gets in her way!
The issue comes when using piers not designed for the traditional paddle steamers. They tended to have plenty of space, often docking on a T (aka “hammerhead”) on end of a pier. Hence plenty of space to stop - or go round again.I had a trip on her some years ago, Tower Pier to Southend and back. When we were approaching Soutend pier we were going so fast that I thought she must be having a trial run to judge conditions , but we just Stopped incredibly quickly. Reversing the paddles has a fantastic braking effect with no prop effect. Was very impressive.
Paddles are extremely noisy on a calm day thoughPractically every pier she uses has been dinged by her at one time or another; she basically has no steerage until she's moving pretty fast, for the reasons given above.
It used to be a bit scary being on the pontoons in Rothesay Harbour when she was being turned in the harbour!
I understand that except for specialized vessels, paddle steamers never have the paddles operable separately, because it is possible for the torque of contra-rotating paddles to turn the vessel over. There's also a fairly obvious engineering reason - you'd need two separate steam engines, and if you watch engines like Waverley's operating, there simply wouldn't be space - the pistons operate directly on the shaft on which the paddles turn. As it's a compound engine, the pistons each operate at different steam pressures.
Something that's rarely mentioned is that she's exceptionally quiet, and it's easy to be taken by surprise as her colour scheme tends to blend with the shoreline! She's sneaked up on me a couple of times on the Clyde.
Strangely, the noise doesn't carry far. On board, as you say, they are quite noisy, but you don't hear it at any distance.Paddles are extremely noisy on a calm day though
We had an outing on the Waverley a few years back and always wondered myself why she didn't have independent paddles and assumed that it could be done with one engine and a clever arrangement of valves, but I guess not. Thanks for the infoI understand that except for specialized vessels, paddle steamers never have the paddles operable separately, because it is possible for the torque of contra-rotating paddles to turn the vessel over. There's also a fairly obvious engineering reason - you'd need two separate steam engines, and if you watch engines like Waverley's operating, there simply wouldn't be space - the pistons operate directly on the shaft on which the paddles turn. As it's a compound engine, the pistons each operate at different steam pressures.
