Daydream believer
Be careful. There are some on this forum who would think that using a winch for such a task is sacrilegeNever heard of a winch?
Very good Regrettably it’s about 60 years. Long enough to know I have to ease the sheet before reefing. If we’re going upwind, we’ll be doing that with the jib in about 16-17kn true. Which is 25-26 apparent. That’s a lot of drag on a flapping sail.That would be a couple of days after the last booze up then
I much prefer the big genoa/smaller main rig to the small jib/huge barn-door main rig.
The former is more balanced and handles better, and because most of the power is lower down and is also in the genoa, you can sail without the main in a strong breeze, which means no leaving the cockpit and you can reef it quickly and easily.
WasYour furling gear must be rubbish then.
I think you’ve cut to the chase there. If it works well for the boat snd intended use, the rig is great. It’s not about the rig, it’s about the package, being under control and having the performance you want. Not getting hung up on where your forestay attaches.Yes. You are correct to point these things out. I am not sure I prefer masthead rig but it does have advantages that are seldom mentioned in these discussions.
Actually, thinking about it, I am wrong, I do prefer masthead rig. Though I don't think it is a matter to get worked up about if a boat is otherwise spot on for the intended use.
He didn't mention electric winch, just winchThat’s a great way to break something!
I’ve witnessed two powered winch induced breakages, one on furling gear…wasn’t coming in by hand, XYDave’s concerns are ignored, furling line wrapped around a large sheet winch…button pressed…
zzzzzzzzzzzz…..bang!!
The second was a main halyard, batten car caught in mast slot….zzzzzzzzzz….bang!!
Both these on big 45 ft X Yachts. The owners didn’t seem concerned, just annoyed by the strength of their gear not handling the IMO excessive loads.
That's just people with more money than brains. If you try to make things idiot-proof, they just bring you a different kind of idiot.That’s a great way to break something!
Don't plan any Atlantic crossings with it then... on the subject of large genoas, the med charter companies used to spec the boats with large genoas to avoid giving the charterers a spinnaker or light-wind sail. Then came self-tacking and code zeros .... I switched my big ex-charter genny for a 110% with a foam luff and an asymetric ..... was a different boat afterwards .... money well spent.
Next boat will be self-tacking with a code zero if I can find one in budget.
Why for the life of me would I want to do that? .... that's what these things are for .....Don't plan any Atlantic crossings with it then
Life is about adventure,Why for the life of me would I want to do that? .... that's what these things are for .....
... and these ....
... you should try them. Saves loads of time and effort.
Been there, done that, got the Tee shirt. Boring, no sense of achievement.Why for the life of me would I want to do that? .... that's what these things are for .....
... and these ....
Haven't sailed across but feel more relaxed and a sense of achievement, arrived with your own efforts.
Happy to be corrected.
What height mast? What size main and genoa? On a 44ft loa ketch we need to reef early up wind. With a 130% genoa we furl it away at 16/17kts True and drop to working headsail. We never reef any of the genoa upwind. Genoa is 65m2. The main we can hang on to a little longer as we drop to 29m2 on the smaller headsail. By 28kts True upwind we are full jib and 2 reefs in main if the seas are big and/or steep. 0ver 30kts we would put some rolls on the jib and triple reef the main.We’ve got a 155% genoa that we use unreefed up to about 13 knots true upwind. After 13 we roll in to the first reefing point; after about 18 we go to the second. Seems to work just fine in 15 years with the same boat. We don’t tend to reef the main until about 20 true; second reef is about 25. Third reef is 30+. All upwind. She heels enthusiastically but with 30’ waterline length and 43’ LOA she needs to be very tippy to go fast. We changed the Dacron genoa to something a bit less stretchy in 2011 and will get a cruising laminate one next year to match the mainsail.
As an aside we have the Tides Marine mainsail track - a very good piece of kit after we fitted it about 10 years ago. Lots of bang for the buck.
You should have been concentrating more on the job in handHad a lovely race with JOG yesterday from Yarmouth to Cowes via Ryde. Extreme stuff... Had about 15-18kts True from just North of East, so a lot of beating.
This thread popped into my head as we passed a couple of cruisers who were also beating. One had a blade fractional foresail and a full main. They were pointing up pretty well, not a huge amount off our angle and the trim looked good and heel looked comfortable.
A few others had rolls in large masthead foresails. They were significantly less weatherly and clearly generating considerably more leeway. Often accompanied with significant flapping from the leach of the foresail. It all looked significantly less pleasant.
Obviously windward performance is not the only consideration, but yesterday there was no doubt at all which rig was providing a better sail and a more pleasant boat to be on for the cruisers.
