VicS
You're just bypassing the switch with another one that you know that works.As I see it it'll determine weather or not the kill switch is functional
No it wont if you just connect another one in parallel.
If the existing switch kills when closed and is sticking in the closed position putting another switch in parallel with it will tell you nothing.
Disconnecting the existing switch, by cutting the wiring if necessary, and fitting another ot just being able to short the two wires together is the way to check it out
