Sea you later
New Member
hello to all,
I have a problem with my D3 190 a-c (port side) engine.
It starts great, idles perfect, no smoke.
at the dock and at sea it accelerates and when it goes over 1500 a few seconds after it studders and can’t get it over 1500.
I replaced both filters and all brand new fuel supply lines and swapped between engines
map sensor, low pressure fuel pump (mounted on the fuel pump) turbos , vacuum pumps, turbo actuator valves…
and still no joy, other engine keeps the parts and works fine.
I sometimes get a fault but it’s only a se operators manual (not shure how to interpret this)
did anyone have this problem?
