weustace
In a second thread which perhaps could be titled "start-of-season woes", I have found (despite fairly frequent lubrication) one of the transom clamp screws on my Mariner 4hp outboard to be seized solid. I have steeped it in oil, poured litres of boiling water over it, attacked it with a blowtorch, and used progressively longer levers until the screw began to yield plastically at the top of the clamp. I have now hacksawed the top and bottom off, and intend to replace the screw with a piece of 316 stainless studding with an appropriate block on one end and a handle of some sort on the other... not too worried about these two details, but quite concerned about where to drill. The existing screw is 8mm roughly, and I am faced with replacing with M6 (and thus drilling largely into the stainless steel and hopefully tapping into same) or with M8 and drilling out all of the stainless + tapping aluminium.
My experience from suffering similar trials in the past suggests that the M6 option may be preferable if I can get a 5.5mm hole sufficiently straight in the screw... views?
Also, am I correct in assuming the new screw should be 316 stainless? Can't imagine an aluminium screw would be hard enough, but given how readily stainless steel work hardens, I was surprised by how much the existing screw yielded—though a back-of-the-envelope calculation suggests a max shear stress at yield of ~180MPa, which is about right for stainless steel and far higher than what one might expect for aluminium.
