Neeves
We have 3 MPPT controllers. We group panels with the same shading characteristics. On the starboard guardrail we have a pair of series wired panels ( to suit a 24v system) on a dedicated MPPT. The port side has a similar series wired set up with its own MPPT. The roving 4x50w flexible panels are wired as 24v and have their own MPPT. The 3 MPPT controllers get their voltage information from the victron smart shunt via Bluetooth so regardless of where they are located in the wiring, they know the actual battery voltage rather than what they see at their terminals.
Correct me if I am wrong.
Normally MPPT controllers use voltage, from the shunt (or wherever), to determine their operation of the panels for which they are wired. In your case this is the voltage of the entire system, not of a specific part. The actual voltage at the MPPT controller is ignored for control of the MPPT controller and hence the panels to which they are wired. All the MPPT controllers will react the same way whether the voltage is high or low for the panels for which (or to which) they are wired.
If the panels effectively use, my understanding, the average - why not have one controller?
If this is correct why the MPPT controllers and not a cheap and (maybe not) cheerful PWM controller?
Jonathan
