Lithium battery fire
I know we have been told not to use AI, nor copy same.
So why ignore the rule and post AI ?
But - I recall reading about an issue with Battle Born batteries and I could summarise the AI script - but it seems much more useful to admit using the AI offering and let readers decide if its relevant.
AI Overview
<snip>
I am quite happy to have my posts questioned as being ignorant - it would be more useful if people who want to criticises posts, any, actually correct the mistakes and lead to a better understanding.
Jonathan
Would take more time than i have to spare.
Thats great because this one trumps the last. Excessive heat in wiring is nothing to do with thermal runaway. I could burn your yacht down with a spanner and a lead acid battery, do you consider that a failing of battery chemistry?
I don't know whose posts you are reading - but maybe you have simply taken a dislike to me and are letting your imagination take hold
I have never mentioned thermal runaway nor heat in wiring or battery chemistry - in fact I have not speculated on why the batteries might have caught fire. My technical input has been ---- zero - which seems to diminish the credibility of your criticisms. At least AI bases their results on published information - you seem to be polishing the art of fabricate
I did speculate on why a truck full of batteries was travelling, toward Melbourne, from Sydney when it would more sensible to ship direct to Melbourne (by sea)
The batteries on the truck are I am willing to bet designed for house hold storage battery use. With huge amounts of solar roof top PV systems in use the government are encouraging us to go for battery storage with large 30% type subsidies. The battery installation industry has gone mad. ol'will
I might agree with William - there are new grants for battery installations.
Jonathan
Jonathan
"At least AI bases their results on published information"
Sorry to have to inform you that this is not correct.
The LLM of your chosen "AI" has simply used whatever it can scrape to lean how to construct sentences. It used published information to lean word patterns and nothing else.
AI is completely unreliable as a source of information. It even suffers from what is described as hallucination. and this is how ChatGPT describe it:
LLM hallucination is when a large language model generates confident, fluent information that is incorrect, fabricated, or not supported by evidence—often because it is predicting plausible text rather than recalling verified facts.
In short: it sounds right, but it isn’t true."
(Misinformation is when a poster ) generates confident, fluent information that is incorrect, fabricated, or not supported by evidence—often because it is predicting plausible text rather than recalling verified facts.
There's a whole lot of that, in here, at times.....
We sorely need an AI+ prompt which will 'separate the wheat from the chaff' in so-called meedja like this.
:LOL:
This is unfortunately, not correct, there are many articles out there that you can read that sum this issue up far better than I could, and with a greater understanding.
But while AI is useful tool, it cannot be relied on as a source of information.
Here is one notable example:
High court tells UK lawyers to stop misuse of AI after fake case-law citations
The AI tool essentially made up legal precedents and quotes, they all sounded very plausible, because that's what it excels as.
As a personal example, when I asked it to summarise a sports season last year, the top persons it listed included people long retired, and some who were actually no longer alive!
So yes, very useful in some situations, but not to be relied on.
And remember its trained on data from all over, some is given higher importance, but its entirely possible previous topics on here and other forums have been scraped and used to train it.
Wish they did that here .... Govt here capped our use of storage batterys and size of the arrays installed - as the Electricity Supply Co's were losing revenue.
The cause is the same for all Lithium-ion batteries, they have a plastic barrier between the anode and cathode which, if damaged, can cause a short circuit.
Overcharging causes lithium plating and dendrites on the anode which can cause the cell to heat up and if it happens for long enough can pierce the separator or cause it to shrink causing a short. The plating also reduces the battery capacity. LiFePO4 is certainly safer than most other Li-Ion chemistries, but it's not immune.
Temp change due to overcharging: Radware Bot Manager Captcha (IOP paper)
From Frogstar:
However, we must stipulate that significant overcharging and undercharging of LiFePO4 batteries can cause damage, reduce battery life and create safety hazards. Therefore it's essential to always follow the recommended charging instructions for optimal performance and safety.
An overview of the issue: Dendrite formation in LiFePO4 batteries: dangers and effects
Thermal runaway temps for different Li-ion batteries BU-216: Summary Table of Lithium-based Batteries
LiFePO4 Thermal Runaway: Causes, Risks, and Effective Prevention
All of the issues can be mitigated against to some degree by using a good BMS, having correct fusing etc.
None of this shows LFP to be dangerous in any way. Spreading this kind of FUD is unhelpful and is causing people to worry about upgrading to safer battery systems.
Nor have you explained the purpose of the thread. You posted a general news story in a boating forum. The story doesn’t relate to boats or boat batteries in any way so whatever your speculation here it doesn’t belong on the forum. We’ve had lots of lithium conspiracy threads of late whose only purpose seems to be spreading misinformation about modern batteries.
LFP is safe. There simply isn’t much more to say on the subject. At this point not only are they tried and tested, they’ve been tried and tested for years by people on this forum. Zero reports of any kind to suggest there is any danger.
I’ll ask again, what is your agenda in posting this?
mmmmmm not actually correct ...
ALL lithium based batterys as in fact do all batterys pose risk ... but the risk varies depending on the format / casing / use / abuse.
Would you believe that a common PP9 battery has been cause of fires .. it has.
One of those nearly caused a fire in my underpants many years ago when I put one in my pocket with a bunch of keys.
I didn't say it was dangerous, I said that it's safer than other Li-ion chemistries provided mitigation for overcharging, over current, over heating etc. is in place.
What is dangerous is thinking that you can use them as a drop in replacement without circuit changes.
Personally, I have to follow the coding rules, and I would need a structural change to use them, so at present don't.
Specifically in what way is that dangerous? The changes are to ensure a good long life for the battery, but aside from potentially killing an alternator there’s no actual danger in a drop in replacement. A good fuse is advisable, but then that’s needed either way.
I would say that correct fusing is essential rather than advisable. Also you need a BMS and charging infrastructure designed for LiFePO4.
Those are good to have but it certainly isn't dangerous without them, the cells will degrade faster but the boat would be safe.
Yes, proper fusing is an important aspect for any battery chemistry including lead. The danger is the same with either, shorting causes heat and therefore fire. That’s not a chemistry issue it’s usually a muppet with a spanner issue.
From Frogstar:
In 2023, the ABYC technical department tested the hell out of lifepo4 batteries to try and recreate some of the potential fire scenarios you hear about on forums and more widely on the Internet.
The reality is that they couldn't cause a fire in a number of drop in lifepo4 batteries, and these guys are experts at destoying stuff in the name of testing. They tested expensive batteries from reputable manufacturers and cheap and nasty ones from unheard of manufacturers. They even put a lifepo4 battery into a fire to see if it added to the fire but it didn't. The only way they could get smoke from one was to hammer two long nails into one. That release of gas didn't cause a fire.
Regardless of the scaremongering on forum like this, there are 10s of thousands of lifepo4 batteries installed on boats around the world. Some will be perfectly installed by knowledgeable people and some won't. There is no evidence that lifepo4 batteries cause fires. None.
Large battery installations have the capacity to produce large current in a fault condition. FLA batteries with bad connections can produce sparks and high current in a short.
Lifepo4 batteries can do this but more so. They have very low internal resistance compared to lead batteries. Dropping a lifepo4 battery into a 40 year old electrical system with old wiring, corroded connectors, inadequate battery isolation, no fuses or the wrong fuses can cause problems.
To create fire, you need heat and duration. A quick spark in an electric circuit from a bad connection may not be a big issue apart from your electronics playing up.
If you install lifepo4 batteries and do what we and many other have done and take real advantage of the tech, there is the increased risk of fire in a badly designed and installed electric system. It's not the batteries that are the problem in my view, it's the electrical system around it. When previously the biggest load on your boat would be the bow thruster with a duration of a couple of minutes, we are now in a scenario where electric cooking with large 3 to 5kw inverters, immersion heaters or in the tropics air conditioning loads. We are seeing large current and long duration from large lithium batteries. Any bad wiring will show up with very high heat with sufficient duration to set fire to anything combustible near that source of heat.
The recent news about the Battleborn battery with a badly installed and designed +ve terminal showed very high temperature when tested under very high current. Because there is nothing combustible in the proximity to it, there doesn't seem to have been any reports of fire. There was nothing in the battery to burn, only lifepo4 cells and some plastic that melted. It's a testimony to lifepo4 cells in a high temperature environment. No fire. No thermal runaway.
I haven’t seen any reports that said the batteries on the Australian truck caused the fire. Online comments from the local community say it was most likely the trailer brakes overheating. Obviously speculation but no one has a more likely theory.
They are full of praise for the driver getting into the middle of the highway and managing to decouple the second trailer.
The fire brigade were able to let it burn itself out because of the driver’s actions. They also mentioned there was little water there to fight the fire, but also that they didn’t want to do that anyway as the toxins would have washed into a much bigger area.
No offence, but you don’t seem to know how science works. Your anchor information is very valuable, but you should avoid posting this kind of thing until you understand the subject. It’s not helpful or useful and will negatively affect people’s decisions for no good reason.
What dangers? There is literally no evidence that LiFePo4 has any danger. Quite the opposite, all evidence suggests it’s safer than lead acid.
Indeed! I have had two instances of lead acid overheating and going in to almost fire situation. Oh and by the way, I check the acid level religiously every year. The CO monitor caught the gases being produced to give us a heads up. The first one was a bad cell caused by old age (9 years) and the second one, a cheapo battery bought in an emergency in Ayamonte that only lasted 18 months.
A lot of people really seem to want it to be. No idea what their agenda is. Last I saw that one looked much more like a galley fire based on the location of the damage (nowhere near the batteries).
Not sure the agenda in starting this thread either. It's a yachting forum so posting stories about random lorry fires seems more than a little off topic unless the fire involved technology used on boats.
You seem very defensive. R u sure you are not just trying to calm something inside your own mind.
The CO monitor gave you warning of Hydrogen ??
