Oil questions
PabloPicasso
12 Feb 2010
I Have a volvo penta 2001 and have usually used a supermarket bought semi-synthetic oil, changed annually along with the filter.
Whilst I have always used the recomended grade, does it matter if its synthetic, semi-synthetic, or not synthetic?
Tranona
10 Nov 2007
Because it hass additives in it that are designed for high output engines not unstressed low output little diesels that were designed 50 years ago. Just a waste of money as well.
Beneteau381
19 Nov 2019
Read Vyv Cox on engine oils, more detail about the differences and chemicals used to protect the then bearing materials and the now bearing materials.
robmcg
17 Sep 2006
In exile in Scotland
Just wondering why the OP used semi synthetic oil? Volvo Penta are pretty clear about using only mineral oil for these engines. I saw a VP2003 run on synthetic oil at the yard once. It had the most brilliant shine to the bores I have ever seen.
PabloPicasso
12 Feb 2010
It was semi synthetic oil from Lidl, or maybe Halfords.
I could not find mineral oil
anywhere.
Where did you buy your oil?
penfold
25 Aug 2003
On the Clyde
It makes no difference; the oil change intervals on small boat engines are so short that the benefits of synthetic or semi-synthetic oil(mainly greater stability allowing longer service intervals) are not obtained, so the extra cost is not justified but using them will do no harm.
KevinV
12 Oct 2021
Not boat related, but my old Suzuki DR800s will burn oil if given (semi) synthetic, but doesn't burn a drop of the dirt cheap mineral oil it's designed for. I don't know the explanation, but I now don't "treat" any machinery to anything other than what the manufacturer specifies.
vyv_cox
France, sailing Aegean Sea.
coxeng.co.uk
anywhere.
Semi synthetic is mineral oil with additions of synthetic, also hydrocarbon but with closer control of molecular length. The proportions of the two are not regulated.
Provided the viscosity and specification are suitable for your engine there is no problem with using it. Many engine manuals still call for API CD spec, which became obsolete in the early 1960s! I think that API CI-4 is an excellent modern substitute.
oldgit
6 Nov 2001
Medway
Having two engines which combined demand 24 litres the easy to find 20L drum is not enough and then buying an extra 5L on its own does not make sense.
Ebay search results in a couple of outlets still willing/able to supply 25L drums, internet search found a company able to sell a 25L drum with the correct spec for around the same money as a 20L drum.
Arrived on the doorstep 24 hours later.
Off to the local motor factor for a couple of good quality oil filters from a known named company, oil and filter change for well under £100.
Done in under an hour with an electric pump and 15 mins of that is getting both engines up to temp to thin the oil.
Then a mere day or two to clear up the mess.
Fortunately have friendly garage nearbye , happy to take the old oil and filters other wise have to book an appointment at local tip.
Garage, which repairs autogearboxes, have a couple of 50 gallon drums to take waste oils/ATF etc.
Not sure if they get paid for or have to pay for the tanker which collects once a fortnight.
