Which engine oil?
16 Jan 2013
I'm looking to the change the oil in a Volvo Penta MD2030 D, trying to track down something suitable, and confusing myself greatly in the process.
According to the manual the required spec is SAE 15W-40 and VDS-2, ACEA E5, API CH-4. It doesn't specify whether mineral or synthetic is preferred and I've seen VDS-2 grade in both. And it looks like E5 may have been superseded by a newer spec these days (E7?) - I haven't found anything labelled E5 so far.
So: If E5 is obsolete what should I be looking for instead? And synthetic or mineral?
I did spot the offering below which lists E3 in the details but shows a picture with E7 on the label. It's a lot cheaper than the 'official' VP oil - any thoughts?
https://www.autodoc.parts/mannol/15768088
16 Jan 2013
Thanks gents. That's a useful resource indeed Andy. Vyv, are you saying that CI-4 is a suitable (or better) alternative to CH-4? And is that an alternative to the ACEA spec, or should I be looking for both?
(And is mineral better for a 21 year old engine?)
Thanks!
VicS
13 Jul 2002
ITYWF Shell Rimula R4 X 15W-40 meets the specification
Tranona
10 Nov 2007
Thanks!
Don't get too worked up about it. These are very simple unstressed engines and the basic diesel oils that widely available to CF 4 and above (which was the spec when the engine was designed in the 1980s) is fine. The important thing is to change the oil regularly because it is non use - or rather short periods of light use followed by long periods of non use that does the harm.
seeSimon
30 Jan 2024
Oil for yacht engines
This is an excellent source of information on oil for yacht engines.
Personally, I use the following in our Yanmar:
Smith & Allan Ultra 15W-40 - Mineral Engine Oil
Another vote for the Cox Engineering site!
Personally, I have found Smith and Allen to be excellent lubes, reasonably priced.
I also use their ATF in my Beta/TwinDisc saildrive.
Imho, (As a retired Chartered Marine Engineer... but no "yotting" expert!) It is possible to over-specify oils for these older type small marine engines. As well as being a waste of money, this can damage machines (as per above reference).
Save your high spec synthetic oils for long service interval automotive applications....if you must! I recently ran a couple of new (leased) VW Tiguans for work.
According to VW, and the cars themselves, they did not require an Oil change in the first year/30 000 miles! I would NOT do this with owned vehicles.
Refueler
13 Sep 2008
Far away from hooray henrys
Must be about time to change oil in my old Perkins 4-107 ... its been about 5 - 6 yrs !!!!
My Yanmar 2GM will be during layup ... having done 1 season
The VP AQ170 will be same - during layup ... 1 season
What Oil ? The Perkins gets standard 10-40 grade as does the gearbox ... the Yanmar will also get a Multi of the recc'd range .... the VP will get same as the Perkins ...
Yes I know - I should know better in my job !!!
All I say is if you do use a cheap budget oil ... change it more frequently as the cheaper the oil - the more recycled oil is in the blend ... with all sorts of additives to meet the specs. What they cannot do is give the oil back its service life ....
vyv_cox
France, sailing Aegean Sea.
coxeng.co.uk
That may be true for your style of boat use but in mine in the Aegean we often motor for voyages of many hours. In a good season our engine will run for well in excess of 100 hours, for which a good grade of oil is a worthwhile investment.
API CI-4 was developed in recognition that sulfur levels in fuel are now considerably lower than they were. This oil has a lower TBN than other specifications, which is beneficial for the engine, plus its additive package is excellent.
vyv_cox
coxeng.co.uk
Thank you for the vote👍
The big plus for synthetic lubricants is their greatly reduced oxidation rate at high temperatures. Modern high performance automotive engines may see constant temperatures well over 100C, which mineral oils do not cope with well. Water cooled yacht engines should never approach these oil temperatures, making good quality mineral oils perfectly suitable.
Tranona
10 Nov 2007
Yes, I know. That is the way my 2030 was used in Corfu, clocking up over 3000 hours in 7 years. However it is typical of the majority of private boats in the UK where average annual hours are typically well under 100. Few boats do more than 40 days a year, and even those that are used more frequently like the cruisers in our club who race as well as cruise don't clock up the hours - maybe 2 30 minute runs every time they go out, or even less if on a swinging mooring.
Refueler
13 Sep 2008
Idle engines are not safe haven for oils ..... they sweat with temp change .... that short run can often not get the oil up to real temp it needs ..... acids and various from fuel etc etc.
So that oil that's only done 100 or so hours a year is still better changed ..... I would suggest that the Oil Filter might have chance of another season ... but ???
Yes I know I should heed my own advice !! What is it they say .... Never look at an auto mechanics car !
thinwater
12 Dec 2013
Deale, MD, USA
sail-delmarva.blogspot.com
^^ This. (My Chem E career was petrol and lubricants)
Old specs were based on fuels that no longer exist.
Hot Property
11 Aug 2015
Hamble
My Verado 200 outboard would register 110 c at a high cruise speed and nudged 120 at full chat.
I was sufficiently twitched to refer to the workshop manual which confirmed it was in spec.
Hotter than boiling water ...
Mercury use a 25w50 oil which is rare to find.
I think I used 10w40 but religiously changed annually.
VicS
13 Jul 2002
Easy to find ...... Force4 stock it.
Halo
10 Nov 2009
Wetherby
This is what I use on my 3YM
15w40 Mineral Diesel Engine Oil 20 Litre , E7, API CI-4/SL (not 25l)
from Rye Oil
16 Jan 2013
Excellent info there, thanks everyone. So the answer seems to be: mineral oil, 15w-40, E7 is fine rather than E5, and CI-4 should be even better than CH-4.
Hopefully I've got all that right, in which case I'll go and track some down!
