Wansworth
As with any powered tools but especially with a circular bench saw concentrate on what your doing keep the work area clean,use a push stick and don’t operate when tired or under the influence ofdrink
Hello, non-boaty question here but confident someone can kindly help.
I want to extend my repertoire of home DIY into fitting e.g. shelves, custom-made cupboards, coving and doorframe. I am a bit bewildered by table saws, skillsaws, mitre saws. If I was to start with one of the above, which would it be?
Are you sure? I thought it was the degree of filtration too.Don’t be tempted into a M class extractor, it’s no more powerful than cheaper L class, it just has an alarm that sounds when it’s full, which is pretty obvious and you don’t need to spend another £250 for!
The makita of the same era managed the same cutting depth yet used a 10" blade as a 12" was renown for blade deflection. It was also built in Japan and oused high end quality. Like yours it was heavy and cumbersome.I’ve also got a DW708 which was when I bought it the largest double bevel, biggest cutting depth etc saw around
You can do it all with handsaws - preferably good Japanese pull saws. Just think, no electricity usage, useful in these days of high energy prices and the exercise will keep you warm and I dare say fitter.
But your not going to match the finish when trying to trim 0.5mm off a large plank compared to a powered saw ?
You would be there all day cutting along the grain of a large hardwood plank, multiple times
But yes it could all be done by hand.
For what you describe above it sounds as if you’ll be cutting a lot of sheet materials.
To start I’d get yourself a couple of fold up saw horses, a couple of 4x2’s and a sacrificial sheet of cheap 11 mm OSB to make a cutting table.
Then get a rail saw, Festool is the most common name but loads of choice now and if you’re planning on using MDF, get a dust extractor. Don’t be tempted into a M class extractor, it’s no more powerful than cheaper L class, it just has an alarm that sounds when it’s full, which is pretty obvious and you don’t need to spend another £250 for!
You’ll now be able to make dead straight cuts every time, perfectly and safely.
I’m mainly doing second fix carpentry now, the basic £200 light weight Dewalt chop saw does pretty much all I need and can be carried with one hand.
I’ve also got a DW708 which was when I bought it the largest double bevel, biggest cutting depth etc saw around, it’s heavy and awkward to lug around and overkill for most second fix applications.
Add a second fix nail gun and you’ll be good to start on your projects.
Learning how to sharpen tools a must before starting
Remember which side ofthe line to cut,some craftsmen score a líneas it’s more accurate
Thanks pal!
Yes I forgot to put a scribing knife ( a Stanley knife will do) and a useful tip is once you have scribed the line use a chisel to cut into it from the waste side to make a groove which the saw blade will then drop into and follow.![]()
Paul Sellers shows that technique. For those wanting to learn using hand tools, his videos are excellent - (1250) Paul Sellers - YouTube
I recently transformed from “proper” solid wood carpentry to building carcase plywood sheet construction.
I made a multi function table (MFT) with 300 holes in the top.
I got a Festool chordless plunge saw, and guide rails.
It is a massive but worthwhile enterprise as now all my edges are dead square, dead straight, all my cabinets are dead square and don‘t look diy at all.
