Birdseye
i have a prout cat (with a single central engine and a catamaran drive leg) and will be insulating the bay with foam over the winter. however, i already know that a significant amount of noise is structure born, most (i suspect) from the drive leg which is bolted to the transom (ie the prop beat).
the drive leg is fastened to the transom using stainless steel bolts through the aluminium mounting plate. the joint is watertight, since the drive shaft runs through the transom and through the centre of this mounting plate
anybody know of an insulating material which i can sandwich between the flat aluminium mounting plate of the drive leg and the transom but which will physically withstand the transmission of 35hp of thrust from the prop, through the mounting plate of the leg and into the boat. in other words, i need physically strong sound insulating material which wont crush. it also needs to be sealable against water.
i thought of sheet lead, or hard rubber, but suspect the former would need to be thick and the latter would transmit vibration.
