New Project
petem
Cotswolds / Altea
www.fairlineownersclub.com
New gear cables going in. Rams look fine but I’ll pull the pins and grease. You like spending my money! ???
I think that's a reasonable compromise. Note that the trim rams can be re-built so I'm not spending too much of your cash!
How clean is the flywheel, any rust? Don't forget to put new RPM sensors in. They're cheap if you buy Bosch from a car parts place.
Mr Googler
11 Apr 2008
No
No rust and I cleaned them. What’s the Bosch part number?
Mr Googler
11 Apr 2008
Arrrrrr…….bugger
Stripped the last bits of the other engine today. Plan was just to pop the end caps off the cooler…..check for corrosion and put back together…..Or……I could snap a bolt off instead ???
this then meant having to take the core out. I don’t know what all the fuss is about. It’s wasn’t scary at all!…..NOT! ?? From the looks of it sea water was reaching the bolt and it was well rusted so a good find in my book ?
Housing is off to the machine shop to drill it out and retap. No big drama.
Full of confidence i then carried on an even removed the wiring harness completely this time!??
BruceK
8 Feb 2015
Conwy
kashurst
10 Oct 2003
Spain
I would drill it out and helicoil it. Cut the stud flush, file it smooth, centre punch center of the bolt, drill 3mm pilot, then go up in sizes until the bolt is removed, Then drill and tap a suitable helicoil. If you can get it on a pillar drill or better a milling machine should be easy.
BruceK
8 Feb 2015
Conwy
Why?! I am familiar with the stud extraction tool from my classic bike and car project days. Using that tool I never had to helicoil or go bigger stud which would not have been practical in most cases. Helicoil in aluminium brings its own host of problems most obvious of which is accelerated corrosion. I'd sooner sleeve and tap than go helicoil on anything.
  • Like
Reactions: vas
vas
21 Jun 2011
Volos-Athens
I've found heat being a decent solution to such issues. Mind, not sure with all the crap next to it but if you could clear orings and inner core, I'd defo heat the hell out of the alloy casting and use double nuts to remove it.
kashurst
10 Oct 2003
Spain
Getting stuck/snapped bolts out of anything is often tricky. Steel in steel - with rust bunging things up usually come out with heat/penetrating oil and perseverance.
Steel stuck in aluminium has been for me always more difficult. If the bolt head has snapped off, it's well stuck. So we could persevere with heat/cold/weld a nut on/impact gripper and penetrating oils. Which may work but with the risk of damaging the aluminium casting. Once the stud/bolt comes out, the aluminium thread will not be great so it may need further work anyway. I guess you have been better at getting stuck bolts out of aluminium than me.
Or drill the old bolt out, helicoil it and it will definitely work and in a predictable time, with least risk to the aluminium part. Good point re helicoil corrosion in aluminium, but easy to solve with tefgel/loctite/various greases. As the oil cooler casting is a very expensive Volvo part, for me I would go for the certainty of helicoils.
Mr Googler
11 Apr 2008
Or give it to a man down the road and think no more about it ???
