MapisM
Just as a quick answer (after I just said the O/T is done to death...!What have you got to run the 3 ?
Besenzoni for the passerelle, BCS for the flaps, Marsili for steering.
I think electric steering's a brilliant idea and as someone who's just bought all the kit to retrofit hydraulic steering and autohelm, wished I searched this out as an alternative!
I guess the principle is the same as the control on a cnc machine. The main difference however would be ball screws instead of lead screws and more commonly, belt driven rather than a gearbox
Fully agree all that BartW. I was following those hoses too. But I decided not to post about it, for fear of getting 10,000 words and pictures in reply.that hydraulic pump in portos pic, is exactly the same like in Blue Angel, for the passerel only,
I can tell from each of those hoses leaving the pump, what it's function: (at least on my boat it is like that)
- passerel gate open - close
- passerel in - out
- passerel fold - unfold
- passerel up - down
3 of those functions have a pressure adjustment valve, clearly visible in the pic, the in - out function doesn't have such a regulater, is alway's at max press
I can NOT believe that in porto's boat the pump serves the hydraulic steering, let alone the flaps,, that electric motor is not up to permanent running during navigation.
Yes to thatThat said, I think this particular O/T can be archived in the "done to death" category by now!![]()
That's interesting Henry. So electric steering is definitely catching on. With your system the rudder angles can be changed independently (ie Ackerman) becuase there is no tie bar. Wonder if Princess have done that. I wouldn't wonder about it too much because it feels a bit of a gimmick.The Princess F55 has individual servo motors controlling each rudder. We have very easy access as the crew cabin is a storage so I can simply pull off a panel to access steering, swim platform hydraulic pump etc. You can center the rudders if required manually and then get home using engines / thrusters when close quarters.
Its still very early days into ownership and exploration of handling but in the case of the F55 the turning circle at speed is greater than the previous P50 Mk3. How much of that is down to the rudder set up? I suspect its more down to the hull design, the P50 really leans into turns and is almost on a knife edge when under way. The F55 is much more sedate and stable. Feel at the wheel is definitely less, the P50 had an electro hydraulic system at the lower helm and traditional manual hydraulic at the flybridge.
I was surprised to see the rudder set up during the F55 build but by the sound of it there are advantages.
Not auctually sure whether they use a classic leadscrew or a ball screw in these Colin, but I suspect leadscrew. But I think plenty of the linear actuators are gear not belt driven.
IPS steering is electric of course. I've only driven one IPS boat enough to get to know it, and that's a 45ish foot very high volume flybridge.That's interesting Henry. So electric steering is definitely catching on. With your system the rudder angles can be changed independently (ie Ackerman) becuase there is no tie bar. Wonder if Princess have done that. I wouldn't wonder about it too much because it feels a bit of a gimmick.
Overall, while I listed some pros/cons above, I'm quite happy to be moving to electric steering and on balance I think it's a good thing . If it fails I'll report back here!
Ah yes of course that makes sense. These things actually need an acme nut, because you want to lock the rudder in position when the actuator motor is not running; you don't want the rudder/tiller spinning the gearbox/motor.Fairly certain it's a lead screw as it has an acme nut, and this would protect the gearbox as a ball screw can feedback with relative ease.
There were, very surprisingly, areas of poor fit and finish on that boat too.Hmmm. I was on that boat in dusseldorf, as were other posters here, just as Hugo was filming it. You can see three posters from here at 23:43
Each to their own but I didn't like that boat. I like the design, but I want P speed, so that ruled out Sanlorenzo SD 90 and 96. But I really didn't like any of the interior choices and many of the exterior choices made by this owner. That's always the thing about custom boats - they are what the customer wants and therefore very different, so you can love and hate different builds on the same hull. Much as I like the SL96A to the point of having bought one, I disliked very much the SL96A that was displayed at the 2022 Cannes boat show - I thought every choice of layout, interior finish, fabrics, furniture, electronics, etc was terrible.
I like the look and feel of teak capping rails but they are hard work for maintenance (ask BartW) and actually the SL 96A has no capping rails at all which I'm very happy about.
I'm also not a fan of caulked teak surfaces other than for decks and staircases. I would never have it on a table top, for example, and I deleted it for the semi circle under the flybridge windscreen on my last squadron 78. I have no choice but to have teak on the stern winch surfaces on this SL96A but they are more straightforward than on the SD 90, with no curves - picture below. This is standard spec. I'm ok with teak here, though I don't love the little teak pads under the cleats -I don't see any engineering benefit.
As others have said, the selected decor and furnishings were not to my taste either. Lots else to like.There were, very surprisingly, areas of poor fit and finish on that boat too.
Surprising on a show boat whatever the owner speccedThere were, very surprisingly, areas of poor fit and finish on that boat too.
Surprising on an SL when JFM says their fit and finish is normally up to a standard that gets him to break out a superlative.Surprising on a show boat whatever the owner specced
Any idea why they sit the cleats on the teak pads. Looks like all the hardware is sitting on those pads. Must be some reason?Hmmm. I was on that boat in dusseldorf, as were other posters here, just as Hugo was filming it. You can see three posters from here at 23:43
Perhaps to align the ropes with the fairleads and/or the winches.Any idea why they sit the cleats on the teak pads. Looks like all the hardware is sitting on those pads. Must be some reason?
