jfm
It has 2 x AnCams in the spec, and 2x AnLights, to help when using AnCam at nightAnd don't forget AnCam (tm)
Yup to all that. Plenty of winter jobs you wouldn't immediately think of, like fixing covers, charging Seabobs, letting folks on board for servicing watermakers, airco, engines, generators, etc. Semco-ing all the teak. Taking 2 crew cars for service and making sure they are run every 2 weeks or so. Deep cleaning fridges, icemakers, ovens, showers. Loads of stuff reallyI’d imagine guardiennage, cleaning, provisioning for owner visits, liasing with manufacturer representatives for maintenance access, collecting people from airports. Plenty to keep one person reasonably occupied.
Yup, 10 of the biggest Lumishores arrived at Sanlorenzo last week actually. 4 across transom, 3 along the aft part of each hull side. Lumishores also on Ribeye chase boat and Williams tender.Great build thread. Will we be seeing another suit of Lumishore's and a set of triple Kahlenberg's added to the list? Will you be letting the yard fit the Bodgeflow™©® system or is that still top secret and will be retro fitted? So many questions lol.![]()
Porto why would that F40 have different number plates front and rear? 00:03 of the video, compared with 00:07. Or 08:02 compared with 08:14.Frequent use that’s how .In the winter bigger boats ( like them all really ) don’t go out much and morph into floating accommodation.There’s always plenty of shore based activities along the CdA to Genoa to find more reasons to visit .
Folks were on the beach a couple weeks ago in Loano ( Liguaria ) Such was the weather .
How ever as a typical ex boaty reason ….this breezed past our marina last Saturday.They all Parked up for stop .
I don’t think I’ll apply. Sounds too much like hard work.Yup to all that. Plenty of winter jobs you wouldn't immediately think of, like fixing covers, charging Seabobs, letting folks on board for servicing watermakers, airco, engines, generators, etc. Semco-ing all the teak. Taking 2 crew cars for service and making sure they are run every 2 weeks or so. Deep cleaning fridges, icemakers, ovens, showers. Loads of stuff really
Plus there is time off - in July/August crew can do long stints with no days off at all, so some amount of downtime on full pay in winter is only fair.
The rear will be the official one .Porto why would that F40 have different number plates front and rear? 00:03 of the video, compared with 00:07. Or 08:02 compared with 08:14.
My hydraulic has a electric 24 v pump mounted on the BCS tank .It does the passerelle as well .So your 4 point relying on a engine drive pump doesn’t apply .That may be a function of the size / scale .Over a certain size only mech pumps perhaps are big enough?? Not following your point. Surely you're not saying your passerelle hydraulic pack also powers your steering, You passerelle pump won't even be continuously rated
Any how I have a worry from a similar experience with electric worm + rack actuators ( your pic says “Acme drill unit “and “lead screw head “ ) in electric gates also Italian brand that uses what look like the same actuator design . The picture is just generic as I said. This steering system uses €€€ industrial proper actuators, not the €50 Chinese actuators you have on gates.
With starting or reversing they jerk .Something to do with the AC motors suddenly getting massive inductive torque ?? They're DC and it's easy with electronics to ramp the voltage
Where as with hydraulic valve operated stuff , be it rams on passerelle, arms on diggers and the ram on your trad rudders there’s no jerk , just a gentle start because the valve I presumed opens up proportionally to get the rams to move .
They may have developed some slow start electrotwackery with the marine PAS , rams to soft start them ? Perhaps D.C. motors Yes
I only skimmed the links and it’s not clear what type of motors ….assume straight D.C. ? Over inverter D.C. to AC ??
Aside I doubt even if there was a initial movement jerk ( compared to Trad hydraulic) ….let’s call it a twitch of the rudder it’s inconsequential due to the weight of the boat and gentle manoeuvring motions anyhow . Yep
It s probably pretty good in a big heavy boat
In the car world ( I know dangerous territory comparing ) electric PAS reduces steering feel compared to outgoing hydraulic where sports car manufacturers have move to electric . It reduces emissions, reduces the CO 2 number = meets manufacturers targets .But dulls the driving experience. But as you say you can dial in a bit of feel on a boat .Exact millimetre track positioning a is NA . Yup, you dont need "feel" on boat steering the way you do in a fast car. A boat is mostly driven in straight lines at slow speed by an autopilot
Summary tech progress with a balance of upsides .
If one actuator fails and doesn't jam the other one steers the boat, so you have nice redundancy. It a failed actuator jams, you remove its pin and the other actuator steers the boat - again. nice redundancy. If both fail then you have a standard steering lock pin on one or both tillers that you'd have on any decent boat, to hold the rudders central and then you steer with engines. Even if you don't have a lock pin, you could use ratchet straps. None of these worries are specific to electric steering - you apply exactly the same thinking to hydraulic steering.One more thing if on the gates theres a power cut or a wire supply failure you can manually disconnect the motor cog from the
“ lead screw “ This means they unlock and can be in emergency moved independently from the motors .
So you need an emergency back up …..a way of disconnecting the actuators if they lose power ….say hard over .
Presume you just pull the pin on the stock ….but you need to lock the blades in there neutral position .Just a thought .
Something like this red locking bar fabricated and attached for emergency
I f iam overthinking this tell me .![]()
Cut and ShutPorto why would that F40 have different number plates front and rear? 00:03 of the video, compared with 00:07. Or 08:02 compared with 08:14.
Volvo launched an electric steering system at the 2005 London boat show………Anyone got any love/hate/worries about this relatively new form of steering?
My boat has the current version of the VP electric steering. Works perfectly as far as my limited experience can tell. There’s no feel at the wheel at all which is a bit odd, but on the other hand it’s really light and only about 3 turns lock to lock. Also, there is no wheel centring at straight ahead, so neat and symmetrical alignment of the spokes is not a thing either, it settles wherever the wheel was left when you turn it on. Presumably these could be engineered in.Volvo launched an electric steering system at the 2005 London boat show………
I was taking the Micky and talking about IPS ……..My boat has the current version of the VP electric steering. Works perfectly as far as my limited experience can tell. There’s no feel at the wheel at all which is a bit odd, but on the other hand it’s really light and only about 3 turns lock to lock. Also, there is no wheel centring at straight ahead, so neat and symmetrical alignment of the spokes is not a thing either, it settles wherever the wheel was left when you turn it on. Presumably these could be engineered in.
Well, mine is. Yes it’s DP-H. But probably the same kit as the IPS uses?I was taking the Micky and talking about IPS ……..
I guess the new Volvo electric steering is for out drives?
The silver 24 v motor is circa €190 btw = carry a spare.
page 52 here https://www.twindisc.it/wp-content/uploads/2016/12/HYDRAULIC_STEERING_SYSTEMS_CATALOG-LR.pdf
Re post #252 .Yup .
Are you absolutely sure its having twin rams + tie bar ?
Just wondering how the pair could be synced? Or later with wear develop syncing issues .Thinking gear teeth stress or some other weak link ? Electrotwackery might come to the rescue,
With worm drives when dead you can’t pull n push them .A hydraulic ram under zero pressure can be manually moved .Not a worm drive .It’s got to turn / rotate. So if an actuator fails ie looses power it jams where it is .Hence needs disconnecting PDQ .
If there are two and one jams via a power loss and as you say is tied by a tie bar to the working actuator then something gotta give = bust .As I said theses screw “ acme drill unit “ + lead screw “ jam solid sans power .
There will be reasons why FG don’t tie them .I get the Ackerman effect fwiw if anything on a big boat ?
So do I, but there's a but.I'm struggling to believe that a passerelle power pack with a little DC motor that small also runs PAS but if you say so...
