vas
sorry, was couple of days off with a bad cold, still recovering and before that working too hard (in order to catch the cold...)
got to wait got another work related book in the making.
Well, if you come our ways give me a call (although Volos is a bit of a detour if you're travelling East to Crete!)
not sure on the tiles myself, mind originally boat had formica type laminate glued on 12mm ply. Extremely strong a pig to remove 36yrs later
comeon, I'd have felt like that if I found that frames and keel were shot, that would be a problem, the others are just a bit of work
regarding the through fittings, yes they ARE solid, haven't got a clue what was installed when though. Difficult to say other than there's a mix of bronzy stuff with galv.steel and pretty sure brass in there, which isn't what the book says
pretty impressive, but iirc from previous threads in here, it wont work as a/f, will it?
will compare to mine, don't look that different, considering I've got keel and a top thing raising a good 80mm from the ply inside.
Alf, my aft deck goes almost to the transom so no need for this. Originallly had some side canvas covers with nasty clear windows. Doubt I'll fit new ones.
Now, to some progress:
First inside managed to remove one ply door frame cutting it to the right size so that it fits in its new position (450mm towards the bow...) Not an exceptionally nice job, as part of the area to cut was thickened (so that it was 25mm or so to fit the alu door frame) so I had to chisel out the new layer of ply and then cut through the main 12mm one. Tried a 45deg cut so that it's easier to fit on the new position after a similar treatment.
On the hullstripping front, I almost finished clearing the bows mainly stbrd side checking where I'm going to fit this bowthuster... Ideally I'd like it tucked just in front of the fwd bulkhead (ex-bulkhead to be exact) but the rule of 1D above and 2D below (where D is the tunnel diametre in my case 185mm) doesnt work (it's more like 1:1:1 I wonder if its a big problem...).
Further and most annoyingly, I'm not sure where the craft water line will be with all these alterations, moving heads from stbrd midship to port and towards the bow, removing the captains cabin/mousetrap on the bow and fitting a double bed thereabouts, fitting a 40kg bowthruster, lighting up the decks by going 10mm down in overal thickness, removing about a ton in coats of paint all around, who knows, maybe only the tip of the keel will be in the water after all and half the P bracket will be on air
Any ideas if I should expect serious changes in w/l? TBH I doubt it will alter more than a couple of cm...
I'll post a new thread probably on the bow thruster fitting with some sketches once i find time to do them
George cleared up the space for one 1250X2500mm sheet of ply to be fitted early next week as weather is too damp over the last couple of days and I'd like the area by the keel to dry a bit.
Ah btw, chine up hull is 12mm, chine to keel its 15mm.
following pics are a bit shocking, but don't worry all'll be fine next week
just different "eyes" cleared up:
and the whole opening:
and a nice detail of the existing (leaking) patch:
Don't mean that it leaked at this point, was probably ok on this spot.
slowly recovering, will try to catch up with some work tomorrow.
cheers
V.
indeed! should create a manual on what not to do when tinkering with boats... I'd probably fill a few pages! The amazing thing though is that it did work, I'm sure this was running for over a decade (if not more!) like that...One of the previous owners was a great Plummer! Good diameter conversion mod with the bottle![]()
Hi Vas
Your efforts are bordering on legendary, deserves at least an ebook on completion. Makes me relieved though I didn't buy a wooden boat I fell for.
In the end I bought an '86 Dutch Steel Cruiser with twin engines and plenty of airflow built in. A design which has been commercially rated 60 miles from port, not the usual river and coastal, so it should get us to Crete, slowly, maybe via Volos
Not sure about the tiles in the heads though, not everything from the good old days was good, personal opinion - tiles are a house thing, not for boats.... but then what do I know.
Hat off for you V... think I would have schrunk into a corner crying facing the challenges you are.... She'll be good as (if not better than) new when you're finished....
Got to love the innovative plumbing though!!
That through hull fittings looks pretty solid from what I can see in the picture .. if it is the original one from 40 years ago, that is pretty impressive.
V... as promised....
Bottom of keel to top of deck @ bulkhead = 75 Cm ...
From top of keel stringer to top of deck @ bulkhead = 60 Cm
..... and this is the aft deck canopy arrangement ... basically a SS tube sliding inside another with a locking bolt. Canvas buttons in at the back of a teak list underneath the flybridge and rolls out as the inner tubes slides backwards. Use tie-backs to aft cleats. Single rope fastened at centre of canvass that is tied to railing on flybridge to form the peak (A) that ensures water running backwards & out to the sides.... simple and effective as I do not wish to have a full aft canopy, but every now & then it is useful to have that lillte bit of extra cover..... got a reversable 1/2 single side as well, in case I need to provide additional wind shelter ...
cheers
V.
