vas
sorry J & A
didn't mean to say I'm definitely going ahead to a straight exit, I said I'm considering...
Actually, I spent some time today measuring and checking heights and elevations. Lifting the shower/heads floor 50mm means that the flat part of the shower tray will be 100mm wider (sloping frames come in place....)
Cannot go any further up unless I change the height of the heads door, which is silly as the four doors are next to another and I'm not going to do it.
So, box as Alf suggests will be used.
J, I've got three rule style immersible (sp?) pumps and 5 or 6 diaphragm ones all curtesy of previous owner, so I'm not tight on the pump front, simply I don't particularly like the extra complication and noise you get out of them.
Spent a few hours only today (got to do the day job occasionally and it was 5h teaching today...) test fitting the two bulkheads that where moved from their original position to the new ones.
Worked out quite well, need another hour or so and should be ready for glueing them down.
First two pics are from the corridor. Remember the corridor is now extended by 500mm, the bow cabin door is shifted that amount towards the bow, and the first heads door (originally by the foot of the steps) is now to the far end of the corridor (port side):
the following pic is from the bow cabin looking aft towards the corridor and staircase.
the next one is the area of the new corridor with the 4 doors around it. Sorry pics are not particularly clear, old xperia has seen better days, less dust and epoxy
final pic shows again the bow cabin, and the support iroko beams (70X70 with a 12X11mm groove for the bulkheads to secure into). Spot the mock for the slope of the slanted bulkhead making the main heads shower area:
An added bonus of the blanking the original heads door at the foot of the steps is that I can redo the staircase more relaxed (as in longer threads, same height) and cut a bit the dash panel above it. Perfectly doable and I gain a two drawer spot above the staircase. Probably get plates/cups/glasses there. We shall see.
Will try to paint strip and sand the difficult to access bits around/under the corridor, so that we can glue in place the various bits over the w/e.
Looks like we'll do a small patch in the stbrd side (generally in much better nick than the port side!) from the lower sprayrail to the keel and replace in the process the 3 seacock flanges and patches/mess around them.
l8r
V.
l8r
V.
