rafiki_
nah, got to find students that really like me too much and I hate them immensely. Not easy to find either I think
V.
I would have thought this job perfect for a pair of scrotes.
V.
Hats off to you.
I would have lost heart discovering something like that.
Thanks Vas, yes the view is a little different here today. My greatest concern is the weight of the snow on Rafiki's canopy. I have seen them collapse under this weight before. We are expecting more on Monday, so will have to find a bit of time to brush off the current covering. Temps forecast below zero for the next week.
I've seen fewer patches on a quilt than your poor boat
Keep up the posts please.
Still wintery here Vas, blizzard earlier, and temp down to -9 c overnight. Great. You have some substantial davvits there. How big was the tender? 30 footer? You will have to look at the ballast when you get rid of that much tin.
Good luck with the quilt. Looking good.
Alf was saying that the passerelle I wanted to fit is too heavy, that will teach him then
I guess these davits are going to be a good 50kg...
Tender was 2.7m rib with ripped baloon thingies that I stupidly threw away at the yard in Athens only to find out that it would cost me a few hundred euro to replace with hypalon stuff and make it as new
Did keep the 9.9hp two stroke engine, anchor, ropes, oars etc though
V.
I......
V.
.......How much heavier are the Detroits it had vs the ivecos? I vaguely remember reading in a spec sheet that the ivecos are 650kg with the gbox each.
I also remember ppl mentioning (YPB I think!) that re-engineering boats with lighter engines alter seakeeping properties...........cheers
V.
JFM, can you start a glossary of terms please, for us boating plebs? Maybe a drop down thesaurus?Great stuff Vas. The angle/overlap joint is called a scarf joint btw, or scarfing is the verb. It adds a nice benefit as you say in making the finsihed surface less prone to cracking by removing a "notch" ie a point or crease with different stiffness from the rest.
Ref the davits, the bolts will for sure be exposed if you remove the transom lining. But surely you want to keep the davits till you've done the aft deck, becuase they form a nice frame for your canvas tent?
Anyway, thanks for the pics. I'm enjoying following the story
