vas
thank you all for the kind words, sorry for the v.late update, I'll answer the Qs and post an update on work done (but I need to try harder to catch up...)
true especially as I'm coming back from the office and I can see her from the distance from the bow. Pics don't do her justice, only got one half decent (need a tele lens and never seem to carry my Nikon, so all pics are from the phone)
spot on, I think it was the day of the first launch and yes it was a stressful day for sure.
there was no such option, i've embarked in a few difficult and time consuming projects, as Pete says I'm fairly optimistic on time to complete (and I'm always way off the mark!) but the satisfaction of putting something right and enjoying it is immense.
very true Bart, wife was getting close to kicking me out, but all is reversed now. Being silently carrying out a few upgrades, very handy as I can walk from home to the office and steal an hour or so in the morning or early afternoon to do some work
thank you doctor...
BTW, it's interesting to note that whilst I really worked physically v.hard during the summer, other than plain exhaustion I was feeling fine.
ONCE MiToS was in the water for a week and after the first couple of trips and the subsequent confidence building, I started realising that various parts of my body aren't in top condition. Left foot still hurts (haven't got a fcking clue what I've done to it!) and both elbows started hurting, became seriously swollen for over a month, couldn't even touch them, and over the last 3 weeks they are slowing becoming normal (and stopped aching) So yes, stress over, and the various subsystems start complaining and demand attention...
Most important of all the right shoulder that was royally fckd up years ago (on the Fiat Coupe engine tuning...) and a tendon is hurting badly even three months after...
Mike and P,
why do you think the launching is hairy? They've been doing it like that for donks, never had a boat drop or fail. Over the 4yrs I was by the slip watching most launches and retrievals other than some funny incidents, haven't seen anything really dodgy.
P., they have pulled a 60ft steel SD boat and a couple of 55 to 65ft GRP planning hulls with no probs. Liftout of such large and heavy vessels means that after the initial balancing and sorting, the massive winch at the end of the boatyard is employed with a thick wirerope and a large pulley. Eases the weight and the poor tractor can get the work done.
the point is to be optimistic dom (and I'm not!), persistent and stubborn I am and it does help as well
you are horribly wrong, I was on that mood only after the second year on the hard
Now I still owe you lot a separate thread on the maiden voyage, but I need a few hours to sort pics and do it, so don't hold your breath, but will eventually appear. So this post is the final update with some more work carried out with MiToS on the hard. Next installments will be with MiToS floating.
As I mentioned in a previous post, there was a small (but constant) leak from the spot where PO had installed the genny inlet. Spot was selected so badly that there was JUST enough clearance for the seacock (was obviously stuck open) and an elbow to the hose that went to the pump. No strainer whatsoever (no space for it) so all grit and mess went straight to the pump. Don't know if that's related but ended up rebuilding the pump which was so worn out, bearing and seals gone that couldn't lift water 30cm to get it to the pump...
Anyway, when I did that patch (sometime during August) i'd run out of the creamy epoxy I'd used on jobs like that so I mixed some of the liquid one and added microfibres and some other powder to thicken it. I obviously didn't do a decent job of it as when bolted the scarfed edges of the patch down epoxy wasn't smoothly squashed filling all the gaps. There were a few really minute hairthickness gaps through which water was coming in. These revealed larger gaps in the epoxy as I sanded the patch down trying to figure out what's wrong (once out on the hard the day after)
Took me an awful lot of time to dry the whole area inside, eventually decided not to remove the patch but widen the gaps and squeeze new epoxy in there. Worked a treat, no leaks afterwards. Didn't have time to apply the copper based epoxy as antifoul on the patch so used some conventional one. Will sand again and sort it in spring when she's out for a couple of months.
And since I mentioned antifoul, remember I did some custom copper epoxy and applied 4 coats all around. I'm really puzzled with the results after one day in the water. Feels like some parts are fine and activated and turning greenish even after less than 24h on seawater, and some others hadn't reacted at all. I know, staying throughout the winter in the water will demonstrate what's wrong, but it was rather odd. I feel it's the lack of consistancy with wife and son coming to help, then getting bored/tired and just dropping the rollers and leaving me to finish the last coat running like crazy against time to keep the epoxy workable... Activation was also done in a hurry and whilst exhausted so probably not effective enough.
stbrd side:
and port:
also interesting to note that ss trimtabs with a few coats of strong primer and the right number of coats of epoxy just came off after two 3nm tests around the port... Will try polishing next time
Will do some housekeeping and sorting photos and hopefully post next update within a week or so.
cheers
V.
Mitos is a fantastic looking craft and just standing on the dock and thinking " I did that " must give a great feeling of satisfaction. Well done now time to enjoy .
Great pic of you. Are you pissed off, or anxious? There must have been a million thoughts going through your head with what could potentially go wrong.
Wow! I've come late to the party and just caught up. I admire your grit in taking up this challenge and seeing it through. Some of those early photo's... I think I may have given in. Well done!
one more time, many congrats Vas,
this is a big milestone for Mitos, for this thread and for You !
now you can start having periods of fun onboard using her, alternated with periods of working on upgrades and or mods, thats what I'm used at ;-)
and not to forget your family, they didn't enjoy much of your presence at home the past 5 years ;-)
I hope from now on, they will often be with you onboard, and have fun time together !
all sorted now, was annoying, but as you say not much compared to the rebuilt that took place.V, Great to see the launch and MiToS floating. A bit of a PITA having a water leak and the fuelling problem & leaks, but after such a massive amount of work those are really minor issues to deal with! Lovely to see hard work pay off. Congratulations.
I prescribe a season of boating, rest and recuperation now before you start on the next one...![]()
thank you doctor...
Absolutely +1!
Just curious, V: judging by the trailer length, it looks like they could handle also much longer boats.
Do you have an idea of up to which boat size they launched with it?
Mike and P,
Just noticed this thread and scrolled back to the first picture - golly that was four years' ago. I'll bet you've had a few blue moments since then as you looked out across that stone pier, To-Do list in hand!
Anyhow, a truly remarkable achievement and I'm sure she'll repay you in spades for putting her back where she belongs :encouragement:
I think Vas made it through the 4 years as in his mind he was only a month a way from launch!
stbrd side:
and port:
cheers
V.
