Simon_and_Tanja
In process of re-wiring the boat and upgrading from single to dual (start and domestic) 12v batteries. In trying to keep things relatively simple and cheap and have opted to install a VSR between the two batteries. I have a 140A dual sensing VSR already for the task.
I also have a panel battery meter (analogue voltmeter) which I would like to use. I envisage wiring this to display charge on either battery via a Momentary 3-position SPDT Centre Off toggle switch. For this to work the VSR would need to be open whilst the meter is engaged. So how can I force the VSR to open even if the batteries are charging?
Is this as simple as lifting the VSR ground wire to +12v ?
Would letting it float have the same effect ?
Never seen a schematic of VSR circuitry so hard to work out if this will work but I'm guessing it should ?
Has anybody any idea what the sense circuit current is likely to be ?
I could (of course) put a 12v 70A NC relay in series with the VSR and drive this from the voltmeter input but this solution hardly aligns with the keeping it simple brief.
