NormanS
SRM - The implication is that for the last 40 years you have been anchoring as you describe, that's since 1980 and limits you to CQR, Bruce and Danforth, I am most impressed.
You carefully lay your anchor in anchorages subject to the full fury of 60 knots, I'm even more impressed
Jonathan
AntarcticPilot - the hold of the anchor is determined by the tension in the rode and that tension is contingent on the power of the engine or the windage of the yacht. It does not matter how big, or small, the anchor is (as long as it is 'big enough') the hold will be identical (unless you magically increase the size of the yacht). Now science might have changed - but no-one has illustrated this change in science, yet
and yes, AP
I think the point you make
A larger anchor will be more shallow set than a smaller one. If the tension is maintained in a straight line pull - possibly not an issue - but if the tension veers//
Jonathan, we've been over this before. In the waters of NW Scotland, winds of over 60 knots are a fact of life. Not all the time obviously, but one has to be prepared, and equipped for the eventuality. We are well blessed with anchorages, many with excellent holding, and perfect shelter from waves. The force of the wind however, is much more difficult to avoid. The further N and W that one goes, the sparser the vegetation, and in many of the further out areas, there are no trees at all, just bare and often rocky windswept hillsides. There is nothing remarkable about laying an anchor in these sort of places. If you want to go there, there is no alternative.
