Portofino
Thx ,5 seconds googling found this:
The effect of spray rails, chine strips and V-shaped spray interceptors on the performance of low planing high-speed craft in calm water - ScienceDirect
This does mention trim, but as you told me that has nothing to do with lift![]()
I think you misunderstood my post on trim tabs and the fact they trim both bow up or down .Sorry you felt my initial response made you “ angry “ if I understood your subsequent “ angry imogi .No worries on that from my side btw .It wasn’t my intention.
Anyhow the meat of your post it’s not testing “ spray rails “ that widen out as they go behind the stagnation line .
Its running constant width 2-5 mm
The rails tested are uniform in width .Indeed above a certain width , they used 5 mm in the scale modal in the tank test it generates far too much lift in the “ forefront “ ( read bow ) area resulting in a exaggerated bow high running trim .Not unsurprisingly. So any stern lift if any is masked , negated by the bow lift .
Pitty they didn’t do a 2 mm forwards of the stagnation and 5 mm or better 7 mm ( within the realms of there scale ) rearwards .
Then report on trim / CoG lift .Never mind .
They didn’t report on a gen rise of CoG like the study I posted .You know the whole boat lifting regardless of its trim angle .
Thats not a criticism btw as they weren’t looking at extra wide flat sections positioned X distance down the hull towards the transom.They just looked at trim . They didn’t measure CoG rise never mind .
This .
you see the same strake forwards is a 1/3 rd the width .A fraction so not to push the bow up .
Only read it once but I will re read it to see if there’s any thing more to add .Tnx for posting .
