The Third Man
Is it to head up closer to the wind in a "puff" as I was taught many years ago? Or does it mean the opposite?
Yes, you luff up relative to the original course, but you are not luffing up as such, just maintaining close hauled in the gust, when the gust passes you have to bear away relative to the luffed up course. I don't know the physics behind it.
In a dinghy which is fully powered up, you luff in the puffs to keep the boat level rather than depowering which gets very tiring very rapidly. As well as keeping the boat level, it gives the advantage of scraping a few more precious feet to windward.
These days, I just leave everything as it is and the boat on autopilot......
No, other way about. The increase in the wind speed relative to the boat's speed brings the apparent wind further back which is why you can luff.Surely it depends if the puff is in the same direction , if so the increase in apparent wind will head you and you need to bear away a bit?
I demand you provide credible links and sources to back up your preposterous nonsense.In the northern hemisphere, the luffing effect of a puff is often more noticeable on a starboard tack than a port tack.
Thanks Andrew when I drew the vectors what you say became blindingly obvious!!!
Standard air pilot licence syllabus, HN. In the northern hemisphere if the air speeds up it tends to veer, and if it slows down it tends to back. So on starboard tack a puff is even more freeing.I demand you provide credible links and sources to back up your preposterous nonsense.
Probably the best overlooked, massive ironic post this yearCan you say " puffs" in a ybw forum? Without getting banned that is? Surely you have to say gusts.
