Sea Change
Yes time is an issue if you're doing a lot of packs. For someone building a single pack over winter whist the boat isn't in use, less of a problem.Indeed - in fact most people now are just using fibre tape for the compression which works perfectly for a few quid a roll. But its worth noting that additional costs are incurred - not everyone will already own crimping tools etc as well as the power supply. When making a comparison it is best to give all the facts.
I am all for building packs - I do at least one every week and sometimes as many as 4 . The biggest issue people will face is the time to top balance their battery pack. A stable supply for £50 as you note , will only be 10amp and so running 4 cells from perhaps 40% full to 100% full can take days. I tend to use a 30 amp supply with the cells in series at 14v to go up to about 90% and then swap to the bench supply and reconfigure to parallel to top balance at 3.6v - even so in a week when I have lots to make the charging is happening continuously from dawn til dusk.
It is all straightforward to do but not everyone wants to spend the time or trust their own electrical skills so the "drop in" option is still popular and better for some.
On my last build I sped things up by charging in series using a 30A 12v, using the BMS set to very conservative limits, and then switched to parallel charging at 10A when the cells were above 3.4v.
The big hydraulic crimper (£30) was essential, but only because I was doing a huge upgrade with new components. The battery type wouldn't have changed that.
