Cowie
I am thinking about changing my lifelines to dyneema does anyone have or had experience of them ?
That is why you splice a stainless steel hard eye at one end and use something easy to cut/untie. Just like most stainless steel set ups.Quick question please: Don't you find Dyneema very tough to slice through fast with a knife, compared to polyester, if you need to in emergency? And how about bending the cut ends together afterwards?
(main example in mind is gettting a thing//person back over the side easily, yes you can have Q/R releases at the ends, but this often doesnt clear the stanchions..)
Thanks for pointing out what I have failed to grasp!
Use ceramic rings for the hard eyes where require but not to worried about cutting it I've got 250 meters spare,That is why you splice a stainless steel hard eye at one end and use something easy to cut/untie. Just like most stainless steel set ups.
I use dyneema for the stuff that passes through the stanchions and runs down each side of the boat bow to stern ?Is there a misconception of lifelines and guard wires occurring here?
You're only thinking of one MOB scenario, namely the one where they have completely lost contact with the boat and you've sailed back to them. The scenario where it is pretty bouncy and you have someone overboard but still clipped on has a strong argument for dumping the lifelines and trying to get them back on board where they are, rather than unclipping them to move to the stern, risking losing contact with them.If a man went overboard for us the easiest and logical location to get them back on board would be the transom and I think with a yacht with a sugar scoop and or steps at the transom that would be the logical place to retrieve. Lifting a person up the sides and over the stanchions would be a nightmare - yes you could cut the lifelines -but to make it easy you would need to cut them all, making it dangerous for those on board making the retrieval .
Really you need to look at the big picture and work out what is best for you, your crew and your yacht. There is unlikely to be one right answer.
Jonathan
I'm considering when there are only 2 on board - and one of them is over the side. I'd rather allow them to fall back to the end of the jackstays and take them in over the transom than have no lifelines to retain the one on board. Which is more important keeping one on board or spending time re-attaching the guard rails you have just cut.You're only thinking of one MOB scenario, namely the one where they have completely lost contact with the boat and you've sailed back to them. The scenario where it is pretty bouncy and you have someone overboard but still clipped on has a strong argument for dumping the lifelines and trying to get them back on board where they are, rather than unclipping them to move to the stern, risking losing contact with them.
In that instance if you have the attachment of the lifelines as a separate dynema lashing (as has been best practice with SS lines for years anyway) then once you have recovered them 5 minutes with a bit of Dynema and some knots gets your guardwires back in place.
Can you tie fender lines with a knot around naked dyneema braid (the 8 or 12 strand stuff)?
