Lifejackets part 2.
TheBoatman
12 Nov 2002
Kent
On Saturday I helped out at one of the RNLI free LJ check days and the results were somewhat alarming
Whilst most of the jackets were serviceable or if you want, fit for use, the amount that was found with faults was somewhat surprising to me. These faults would have meant that the jacket would not have inflated should the wearer have entered the water. A quick list!
1. Gas bottles loose or not screwed in and lying loose inside the jacket.
2. Gas bottles that had fired/leaked and were empty.
3. Leaking bladders.
4. Crushed mouth inflator which let the air/gas straight out again.
So fellow members why not just take a quick squiz at your LJ’s and un-screw the bottle check it and screw it back in tightly and then blow it up by mouth to see if it holds air?
Alternatively take it to the next free RNLI LJ check and let them do it for you.
BTW for those interested it was approx. 10 failures in 41 checked.
Moose
1 Nov 2001
West Sussex, Boat in Chichester
I know somebody who had a load of British Airways lifejackets. He has had them for 20 odd years and decided to chuck one in the marina the other week, it worked perfectly, the light came on and the whistle worked, I think they are meant to be serviced every 6 months!!
<hr width=100% size=1><font color=green>Toscana is for sale!</font color=green>
A1Sailor
4 Jul 2004
Banned from Rockall
Haven't there been warnings about this posted all over the place by, among others, the RYA, MCA, DTI and RNLI? They basically said "check your lifejackets"......
Windfall
9 Jan 2003
Hants
After being convinced that ours (at least 10yrs old and although HWMO says he's serviced them the household accountant hasn't seen any documentary evidence!) I decided that I wanted a newer, more comfortable one.
So we went home, geared up the bath & the children and threw my lifejacket in....where it promptly did nothing /forums/images/icons/frown.gif. Just about resisted the ' I told you sos' and rushed off to try his. Guess what? It inflated immediately /forums/images/icons/shocked.gif.
Erm.....back to the household accounts.....has he increased the policy recently....has he been planning the perfect murder?/forums/images/icons/wink.gif
Anyway can't find any Sowester re-arming kits so now he has a new lifejacket too, but a salutary lesson and the new ones will be checked.
janie
Devon
Do you find that the strap comes across the bust, and is most uncomfortable? It doesn't seem to make any difference which make I try - I don't think that they're designed long enough for women!
Talbot
23 Aug 2003
Brighton, UK
I had some old beaufort lifejackets that seemed to be fine. I blew them up hard every year and left them and they were ok, but I decided to check a CO2 inflation, and it blew apart the seams, as did all the others. So just an oral inflation is not good enough.
TheBoatman
12 Nov 2002
Kent
Re:#3
Nige
Leave my bladder out of this thank you very much,,swine<s>.
I'll have you know that me bladder was checked and found to be in full working order, so there!
According to the RNLI chappies if I ever pull me toggle, I'll get instant filling of me bladder with no way to empty it unless I poke some type of gismo down the end of my "if you need to add more air to your bladder use the tube provided" thingy.
Unfortunatly due to my age (sorry LJ's age) my gismo fell off years ago so I can't deflate me bladder but then I think why would I want to do that if I'm actively relying on a full bladder?
According to some of the more rakish members of this forum [like ken,Jimi and oldsaltz] they recommend using beer to fill yer bladder but I'm not convinced I'll float?
Colin_S
20 Jun 2004
kets - help clear your nose
Re:#3
In the interest of self preservation, I've just manually inflated my jacket and given it a good squeeze and it seems to hold pressure OK but I'm buggered if I can get all the velcro to go back in place now I've let the air back out of it.
TheBoatman
12 Nov 2002
Kent
Re:#3
Colin
You've seen through my ruse, I only posted this thread so that I watch all you sailor types wandering around with open necked LJ's <s>.
Useful tip,,,try not to fold the bladder along the same lines as before, helps stop wear at the folds.
Peter.
Windfall
9 Jan 2003
Hants
I agree there are lots of practical things that don't seem to consider the female anantomy....p'haps there's a market opportunity here?
But re' the bust issue....I've sent you a PM
Sharon
milltech
31 May 2001
Worcester
www.iTalkFM.com
My dear, if you must undertake unnatural pursuits not suited to ladies, such as driving cars or sailing, you must expect a little discomfort.
(ducks to avoid flaming)
<hr width=100% size=1>John
http://www.on-line-marine.com
Gunfleet
1 Jan 2002
Orwell
Ladies\' Lifejackets
You may suffer discomfort but most women have one huge advantage over men while sailing - their height. Anywhere between 5' & 5'8" seems about perfect. Those of us in the 6ft range have scars all over our heads! Good luck with the search for the perfect ladies' life jacket. I'm sure my wife would be pleased to know what answer you find.
