Tranona
Things have changed rapidly in the last couple of years. when I planned the new electrics in my project boat 3 years ago AGMs were the best option for my usage pattern. 30% higher price than FLA but 50%% greater cycles plus faster charge acceptance and lower self discharge. The then higher cost of lithium plus charging controls and lack of charging (no solar) could not be justified. Now of course that has changed and overall cost of lithium and charging (extra B2B) for the same usable capacity would be similar. I could also have used a cheaper engine start rather than the super expensive AGM needed to fit the space.This interested me because we recently upgraded our batteries and went for more batteries and from wet to AGM. We didn’t consider Lithium because general scuttlebutt indicated they can be problematic with some insurers and a quick search online reveals that can of course catch fire in certain circumstance and can be a problem for fire services. To be fair I am not against the concept but with lots of other work to do I didn’t want the phaff of changing charging systems and I took the view that we might consider them when the batteries next need replacing, when I would have more time to research properly and things will likely have moved on a bit.
Posing the question to Mr Google, his AI response on the relative safety of Lithium v lead acid was:
Lithium-ion batteries are generally considered safer than lead-acid batteries, but both can be safe if handled correctly:
- Lithium-ion batteries
These batteries are less likely to leak, overheat, or explode, and don't contain corrosive acid. Lithium-ion batteries do have a small risk of thermal runaway or fire, but proper handling and charging can reduce this risk.
No point in changing now as the AGMs are likely to last 10 years or so the way they are used. similar will apply to you, I expect so when the time comes to replace yours there will be new choices - probably an on board mini nuclear power station!
