rib
I sail a 41 single handed. Ease the main sheet so boom can move abit but not across the deck. Head in to wind on ap and as the main zig zags from side to side raise the main. I also have heavy clothed sail ?
There are lots of people who have very firm opinions on many things - but doesn’t mean they are always right.Am about to fit some.
John at AAC:
Attainable Adventure Cruising
whose design I am copying, is very firm about NOT hanging the upper blocks off the spreaders.
Interested to see that you believe the outboard ends of spreaders are secured to the cap shrouds. It has always seemed a good idea to me.If all else fails:
Hoist / open the headsail and sail close hauled.
Let the mainsheet go.
Slacken lee side lazyjacks, and pull forward if need be.
Hoist main in slipstream from headsail.
I do all my sail hoisting and reefing at the mast when single handed or crewed as it's easier to spot problems before things get jammed or damaged by brute force and ignorance.
As to not hanging lazyjacks from spreaders, we are all free to make our own choices. I do not seek publicity and no longer run a sailing business but have sailed a fair bit including north of the Arctic Circle, and also sail single handed. My choice is to attach lazyjacks to the spreaders to open the throat. This has worked without any problems on my four boats since first rigging lazyjacks in the early 80's. However, I always ensure the outboard end of the spreader is secured to the cap shroud and can not be pulled below the optimum angle. Allowing a spreader to droop puts the rig at risk so AAC is probably being dogmatic to cover themselves.
If you insist. I'm quite keen on the KISS principle. Adding strings that catch the main when hoisting, that apparently need adjusting to allow the sail to set, that rattle on the mast, and generally get in the way seems to be a pointless expense and effort. I hoist and lower from the mast and have no difficulty in flaking as it drops and then onto the boom with sail-ties but then, as Dunedin commented, I do not have one as big as his. On OPBs with the infernal contraptions, usually allied with an ugly stack pack, I find the faff of hoisting while waiting for the sail to be perfectly centred takes concentration away from where the boat is actually pointing. But each to their own.Do tell more.
Likewise - we have an electric halyard winch and the millisecond between pushing the button and it raising the batten past a snag point can be frustrating. With the autohelm steering to wind, manual hauling at the mast when the stars are aligned gets it up past the danger zone at the first attempt nearly every time.I made my own that fold easily out of the way when not needed, video here. My preference though is to use autohelm to keep head to wind and go to the mast as opposed to trying to do it all from the cockpit...
On my current boat with Kemp mast there are built in clamps on the end of the spreaders, and root fittings that defies any downward movement. I can (and do) stand on a spreader without any concern that it will droop.Interested to see that you believe the outboard ends of spreaders are secured to the cap shrouds. It has always seemed a good idea to me.
I do this by having a bulldog clamp permanently fastened to the shroud supprting the spreader. This was condemned by some on here many years ago when I first described it. (Not that I took any notice!).
How do you secure your spreaders to the cap shrouds?
My Prout catamaran came with a bodge fitted by a so called rigger; a copper ferrule crimped to the cap shroud. Of course this had steadily corroded the alloy end plug and the the spreader was starting to droop. Rather than re-rig I continued the bodge by rebuilding the plug with epoxy resin and likewise encapsulating the ferrule. No problems in the five years I owned the boat.
On the other boats I used s.s. bulldog clamps, (like you) of the type used to make temporary eyes in flexible wire, to support the spreader ends. You have to be careful not to over tighten though as the U bolt side of the clamp could cripple the lay in the shroud. Obviously, keep the bolt ends under the spreader and if necessary cover to prevent any chafe.
Closed minds!I find it interesting how many people will vociferously and authoritatively condemn something they have no experience of. I was criticised in my YM Instructor exam (many, many years ago) for anchoring under sail in light winds by laying the chain on the run and bedding the anchor in by turning the boat just before checking the chain so that the chain was clear of the hull. No No, you can't do that they all said. It was a technique I had often used on my own boat and learnt from the book "Practical Yacht Handling" by no less an authority than Eric Tabarly.
It seems lazyjacks are both a necessity for safe and easy dropping of main sail - and a curse when lifting the main since battens get stuck in the lazyjacks lines.
Me too. The ability to drop the main safely and reasonably tidily from the cockpit far outweighs the buggery factor of battens catching the lazyjacks. I also have a light downhaul on the main, so I can get it down all the way and make sure it stays down in any conditions.Whatever the the complaints about lazy jacks may be, I thoroughly recommend them.
On the other hand - drop mooring; back to cockpit and unroll genoa, sheeting to point head in right direction before fully unrolling and sheeting in; release kicker and mainsheet; clear moorings and when in open water stroll forward removing sail ties on the way; hoist main; back to cockpit, sheet in/kicker on; take tiller. No need for autohelm, motor, extra crew. Parking is under main only - stop at buoy, pick up strop, back to mast and drop sail flaking the luff as it goes. Only if tide is stronger than wind - nearly all this year in the sunny north - does this need modification but I was probably motoring anyway.
