Kittrina - dismasted.
geem
27 Apr 2006
Caribbean
My sympathies.
Yep, boat stainless like 316 is a crap material. Shiny bling. A good material will never fail. It’s mad, we know it fails, but we repeatedly use the stuff.
I have said this before but 316 ain't what it used to be. Our original 316 s/s is far superior to the new crappy Chinese s/s that is sold as 316.
The old stuff doesn't corrode.
fredrussell
24 Mar 2015
I was thinking along these lines a week or so ago. My standing rigging needs doing - nowt wrong with it but it’s 15 years old - but how does one know they’re buying as good a grade of rigging as the outgoing stuff?
My friend had his standing rigging replaced a year ago and there’s rust on it now. Not huge amounts, but there was absolutely no rust on the previous standing rigging after 15 years of use.
sarabande
6 May 2005
Ooops, Rum, sorry to hear. Well done on saving the crew and the boat. That will keep you out of trouble for a week or two. And you can always use the old mast as a flagpole and CCTV in front of your pool.
Best of luck. Keep posting pics.
Rum_Pirate
23 Aug 2004
A tiny Island, Caribbean
The Corsair F-27 I have was built in 1991.
Don't now which quality and source for stainless steel was used.
Doubt that any fittings into deck were replaced in the last 30 years.
geem
27 Apr 2006
Caribbean
My chainolates are original but 12mm thick 316s/s bar with no external signs off rust. We have checked the inside and all rust free.
We changed the aluminium toerail a couple of years ago and reused the 1980 M8 s/s bolts to bolt the new toerail back in. All bolts rust free and removed from the aluminium torail painlessly. The old toerail has 200 bolts each side. The new one went back with 150 bolts each side. The quality of the old stuff is a different world
Edit: corrected chainplate dimensions. 12mm not 10mm thick
Rum_Pirate
23 Aug 2004
That’s quite a eye opener for thousands of boats with S/S fittings
Wonder why insurers don't ask for samples of various fittings to be removed and checked every ten or so years.
A surveyors visual inspection would not find it (cavity corrosion).
One 1/2"stainless steel nut I tried to move on a structural fitting below deck sheared off at first movement (same day another story. But it looked OK.
The ones in the pic below are from other side of the hull.
These are the bolts
Rum_Pirate
23 Aug 2004
the tang in question
srm
16 May 2004
Azores, Terceira.
Yes it does exist. The better grades of stainless won’t fail. Ditto of titanium and bronze and many other alloys.
The Waverider buoy I mentioned earlier was in the 1970's. According to the instrument manufacturer the hull and all other metal fittings in the mooring line were made of high grade marine stainless steel. (I forget the detailed spec). They are still in business so must have known what they were doing.
Zing
7 Feb 2014
I agree, new Chinese 316 is not as good as old European sourced stuff. That’s a different issue altogether though. My comment was that there are better alloys that are far superior, cost little more, it at all and should be used instead of 316. Actually, even better still to use composite materials, which modern builders are increasingly using for chain plates in particular.
I disagree that old 316 does not corrode. It does in the right environment or circumstance and catastrophically so.
geem
27 Apr 2006
Caribbean
I am sure you are right but at 42 years old our 316 is fine. It's also heavily built which helps with longevity
Tranona
10 Nov 2007
Same with my even older Golden Hind. However unlike many designs (such as the tri in this thread) all the chain plates are external bolted through the topsides with stainless backing plates inside rather than passing through the deck. A disaster waiting to happen unless the seal through the deck is perfect and the attachment below is not hidden or embedded in a knee or a bulkhead. Many 1970-1990s designed boats fail in this respect - and the chain plates fail through a combination of crevice corrosion and stress, just as in the photo in post#34.
Probably little to do with the quality of the material - even the best 316 is susceptible to crevice corrosion.
Design of shroud attachment has come a long way since then with first through deck tiebars down to the keel through such things as internal structural bulkheads or dedicated webs to the keel load bearing structure or more recently back to external chainplates bolted through to laminated internal structures and even composite laminated into the hull structure.
